cs_giuseppe
May 25, 2017Apprentice
Change Samba idmap with AD
Hi I have a nas that was installed long ago with a firmware pre 6.5 and then upgraded to the last, with this nas the idmap with ad is different that one started with a recent firmware. It's poss...
- Jun 01, 2017
Hi,
SOLVED !!!
here the step
- Switch from AD to Local users.
- NEW - Disabled samba in each share
- Wipe the permissions under File access tab / reset of each shares settings section.
- Edit /etc/samba/smb.conf to replace tdb by: rid
- Execute: net cache flush
- NEW - Reboot
- Join AD with "trusted domain" unchecked.
After these steps now idmap use rid.
Thank for all suggestions
jak0lantash
May 28, 2017Mentor
Please confirm if these are the steps you followed:
- Check smb.conf that it's using rid instead of tdb.
- If so, reapply the permissions: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
cs_giuseppe
May 31, 2017Apprentice
Hi
I made all on the test nas:
but nothing, still tdb
I founf when the problem arise, with fw 6.5.0 there are problem with ad auth and I check 'trusted domian' this set the tdb and now even is uncheced no rid.
- jak0lantashMay 31, 2017Mentor
Before 6.5.0, it used tdb.
Since 6.5.0, if trusted domain is unchecked, it uses rid.
Since 6.5.0, if trusted domain is checked, it uses tdb.
Once it starts using tdb, the GUI doesn't allow you to switch back to rid.
- cs_giuseppeJun 01, 2017Apprentice
Hi,
SOLVED !!!
here the step
- NEW - Reboot
