cs_giuseppe
May 25, 2017Apprentice
Change Samba idmap with AD
Hi I have a nas that was installed long ago with a firmware pre 6.5 and then upgraded to the last, with this nas the idmap with ad is different that one started with a recent firmware. It's poss...
- May 31, 2017
Hi,
SOLVED !!!
here the step
- Switch from AD to Local users.
- NEW - Disabled samba in each share
- Wipe the permissions under File access tab / reset of each shares settings section.
- Edit /etc/samba/smb.conf to replace tdb by: rid
- Execute: net cache flush
- NEW - Reboot
- Join AD with "trusted domain" unchecked.
After these steps now idmap use rid.
Thank for all suggestions
cs_giuseppe
May 31, 2017Apprentice
Hi
I made all on the test nas:
but nothing, still tdb
I founf when the problem arise, with fw 6.5.0 there are problem with ad auth and I check 'trusted domian' this set the tdb and now even is uncheced no rid.
cs_giuseppe
Hi,
SOLVED !!!
here the step
- NEW - Reboot
