jaykurb
Oct 17, 2015Follower
Changed from BT homehub to Netgear D6200 no longer access NAS devices
So, pretty much as the title says, I changed from BT home hub 3 to Netgear D6200 and now the NAS devices are not accessible. I have kept the BT modem and just replaced the router. The new netgear...
Oct 17, 2015Guru - Experienced User
This a readynas forum, so WD MyCloud and QNAP are off-topic.
One possibility is that you had set up static IP addresses, and the new router uses a different address range. If you recall the IP addresses the old router was using, you can try setting the new one to use the same range.
