beefybarn
Sep 29, 2014Aspirant
Changing disc on a 104
Hi
I am running a rn104 with 3x3tb and 1x2tb drives in raid 5. I have just got another 3tb drive, can I just pull the 2tb and replace it with the 3tb and let the volume rebuild, also can I hot swap or should I power down
Thanks in advance.
Thanks in advance.
- vandermerweMasterLog a support request.
Is the disk on the HCL? - beefybarnAspirantRight finally got that sorted, turned out it was a faulty drive :shock:
Now I hve got hold of 2 x4tb drives which I am going to swap with the 3tb ones, does it matter which drive I pull first, can I just start with drive 1 and work along (I will be changing them all to 4tb eventually).
Thanks in advance. - vandermerweMasterYou said you had tested the drive when I asked, are you saying it passed your initial testing and failed on subsequent testing?
Testing a drive should use vendor tools extended or long tests, shorter tests have false negatives. - beefybarnAspirantYes tested fine in hdtune but when I tried the vendor tools it showed numerous errors so sent back.
