dnkforums
Aug 29, 2011Aspirant
Changing file and folder ownership
Hi, I've recently upgraded by ReadyNAS Duo to take 2x2TB drives. I copied the old files off onto an NTFS partition then have copied them back on again via NFS (to the media share) Unfortunate...
arjoseph1
Aug 30, 2011Tutor
To open the file permission for NEW files, follow the steps below:
Configuring Advance CIFS Permissions:
1. Go to Share listings
2. Click Cifs icon of the specific share name
3. Scroll down and put a check on "Automatically set permissions on new files and folders" under Advance CIFS Permissions.
To open the file permission for EXSISTING files, follow the steps below:
Configuring Advance Options:
3. Go to Advance Options tab
4. Share folder owner: (type the share name)
5. Share folder group: (nogroup)
6. Put a check on "Set ownership and permission for existing files and folders in this share to the above settings" and click Apply.
P.S.
After you put a click on the Apply button the check will disappear inside the check box, it's normal because it's an action box.
P.S.
