Marvell
Nov 23, 2011Aspirant
Changing http&https apache ports
Hi all I'm wondering If its possible to change to higher ports the default ones for apache (http 80 and https 443). The question is that I would lile to access some addons over Inet, but I cant ...
mdgm-ntgr
Nov 23, 2011NETGEAR Employee Retired
I would say you need to get a different router. Or look into if you router supports DD-WRT firmware: http://www.dd-wrt.com/site/index
Changing the ReadyNAS configuration in the way you want is not supported and a firmware update would overwrite those changes.
