Marvell
Nov 23, 2011Aspirant
Changing http&https apache ports
Hi all I'm wondering If its possible to change to higher ports the default ones for apache (http 80 and https 443). The question is that I would lile to access some addons over Inet, but I cant ...
Marvell
mdgm wrote: Changing the ReadyNAS configuration in the way you want is not supported and a firmware update would overwrite those changes.
The firmware update isn't a problem, after new update I must just change the configuration again.... that's all.
About the router replacement isn't possible at all, because at the moment I'm using the router provided by the Inet provider.
