eltel1
Mar 08, 2012Follower
Changing NAS from Seagate BlackArmor
Hi, I have a Seagate Black Armour NAS 220 with 2 x 1TB drives (SATA-II I think). Am I being optimistic in thinking I can just swap these out of this unit and into my new Ready NAS Duo V2 when it ar...
Mar 08, 2012Guru - Experienced User
If you move the disks, the Duo will wipe them, so you will lose your data.
They will likely work, though you should check the models against the HCL.
