jim852's avatar
jim852
changing RAID settings
Can anyone help?
Iv just bought an ultra 6 and when booting up for the first time it installed X-Raid 2, I actualy want to run X-Raid 1, does anyone know how I can change the RAID settings?
  • StephenB's avatar
    x86 platforms use xraid-2. Why on earth would you want to use xraid-1????
  • Simply because I dont want to loose half of my disks in backup
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    X-RAID (1) is only available on some EOL products as StephenB indicated.
    X-RAID2 is better than X-RAID
    I think you are confusing X-RAID2 vs X-RAID with X-RAID2 dual-redundancy vs X-RAID2 single-redundancy.
    You are also confusing RAID with backup. RAID provides redundancy/high-availability. Important data primarily stored on the ReadyNAS should be backed up to another device e.g. a USB disk
  • Thanks to you both, its honestly appreciated. Being new to this I am more than willing to accept that I missread the information or at least missunderstood it. If either you or StephenB have any tips to pass on Id be glad to have them. Id like to say that I owe you a pint for your help but the distance is a litte awkward.
    Best regards
    Jim
ProSupport for Business
