kalo1
Sep 29, 2011Aspirant
CIFS Default Access
Why is it that files saved from Windows 7 to CIFS shares on my ReadyNAS NV+ (RAIDiator 4.1.8 ) only have read access when the Default Access is set to Read/write in Frontview? This is causing problem...
Sep 30, 2011Guru - Experienced User
You are saying that you clicked on "Automatically set permissions on new files and folders.", with "Everyone rights" set to read/write for both folders and files - and that you are still not getting write access?
kalo wrote: Thanks for the reply. Have done all that you suggest but new files are still created without write access, except to the folder owner. Could this be a Security Mode issue? I am using Share security as this is my home network, would changing to User security be the solution?
