Angus73
Feb 28, 2018Aspirant
JFS524E cannot access neither reset to factory default
Hi,
I am trying to set up a ProSafe JFS524E (unmanaged plus) switch.
I don't have a dhcp server on my network, so I have connected my PC directly to the switch, set up IP as 192.168.0.210/24, disabled antivirus and firewall on the PC (winXP Pro Sp3, with admin rights).
Pinging 192.168.0.239 (which seems, according to [1], the IP address the switch falls back to if it doesn't obtain any from DHCP) I don't not obtain any answer.
I tried all of this also with another PC (linux), with the same result.
I am not able to manage the device through the UM+ Configuration Utility, because I can see the device is listed, it asks me for a password but regardless of the password (except I leave the password field blank, in which case the answer is "Password cannot be empty!") the answer is "Network error. Please ensure your link is up and retry!".
This happens with both UM+ config utility v1.2B20 (supplied on the CD that came with the device) and v2.5.3 (last version as stated in [2]). (With v2.5.3 I have a further problem, i.e. there is a "username" field to fill in, neither providing "Admin" nor leaving it blank works, but I am not sure which username is correct, and even whether the version 2.5.3. supports my device or not.)
I am trying to understand how to "factory reset" the device, but I am not sure to know which is the factory default reset button. It seems [3] that the hole in the front of the device is not the one I need to do the factory reset. Btw, I tried to use this front button:
- holding it pressed down for 30 seconds, while the device is turned on;
- pressing it with the device turned off, holding it pressed down while turning on the device, and holding it pressed down for another 30 seconds after the device turns on
...but the problem remains.
Another article [4] says that the default IP address is 192.168.1.1, but using this IP/subnet gives me the same results.
Many other links, articles or threads from this forum ([5], [6], [7], [8]) did not help me.
Could anybody help me please?
Thank you very much for your help and patience,
Andrea
[1]: https://kb.netgear.com/30418/What-is-the-default-IP-address-of-my-NETGEAR-Smart-Managed-Plus-Smart-Managed-Pro-or-Insight-Managed-Smart-Cloud-switch
[2]: https://www.netgear.it/support/product/JFS524E.aspx
[3]: https://kb.netgear.com/24679/How-do-I-reset-a-smart-switch-to-factory-default-settings
[4]: https://kb.netgear.com/6663/ProSAFE-Factory-reset-routers
[5]: https://community.netgear.com/t5/Managed-Switches/JGS524Ev2-Password-reset-assistance/td-p/1029765
[6]: https://kb.netgear.com/1148/What-are-the-default-web-interface-passwords-for-NETGEAR-devices
[7]: https://kb.netgear.com/31261/How-do-I-access-the-admin-page-of-my-ProSAFE-Web-Managed-Plus-or-Click-Switch
[8]: https://kb.netgear.com/12344/Unable-to-detect-the-ProSAFE-plus-switch-using-the-UM-utility
they replaced it with a JGS524Ev2, which works.
Thanks,
Andrea
- JohnC_VNETGEAR Employee Retired
Hi Angus73,
Welcome to our community!
It seems that you already tried everything just to factory reset the switch. You can only use the reset button just below the power LED. I suggest you to open a chat / case online on NETGEAR support and please be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
- Angus73Aspirant
Hi JohnCarloV, and thank you for your answer.
I would like to have some other suggestion, if possible, because:
- The device is no longer under (phone/chat/email) warranty, and as far as I can understand this prevents me to ask for chat support, doesn't it?
- The device is one out of 5 (five), among which I have tried two of them, with the same results. It seems strange to me that they experience the same (hardware?) problem. Anyway, I can try to have a look at the other three and see if they have the same problem.
- If the suspect is hardware problem, then I can understand that the device(s) are under (lifetime) warranty, but I cannot find the way to claim for a replacement. And what if I obtain a RMA, but it turnes out to be not a hw problem?
Is there any answer to my doubts?
Thank you!
Andrea- JohnC_VNETGEAR Employee Retired
The admin and password is actually a known issue on the old firmware and in the ProSAFE utility. But it seems that you are running the latest firmware and it could be another issue. Have you tried to use another PC just to isolate and try other ports of the switch? You may try setting your PC to 192.168.0.200 /16 then try to ping 192.168.0.239 and let's see how it goes from there.
That's not good. How about connecting it to a DHCP server just to check if it will be receiving an IP? Then run the ProSAFE utility.
- Angus73Aspirant
JohnC_Vwrote:That's not good. How about connecting it to a DHCP server just to check if it will be receiving an IP? Then run the ProSAFE utility.
I have just set up a (linux) DHCP server on the fly. Double-checked the server config and tried it, by connecting a linux client PC, and the DHCP server works. Then I tried these steps:
- connected the switch to the DHCP server
- turned the switch on
, and the server does not show any lease granted.
then
- connected the client to the switch
, and the client regularly obtains the lease.
So it seems the device is not able to obtain a DCHP address.
Double checked the behavior with one other device also, same result. That's really weird isn't it?
