Angus73
Feb 28, 2018Aspirant
JFS524E cannot access neither reset to factory default
Hi, I am trying to set up a ProSafe JFS524E (unmanaged plus) switch. I don't have a dhcp server on my network, so I have connected my PC directly to the switch, set up IP as 192.168.0.210/24, d...
- Mar 09, 2018
they replaced it with a JGS524Ev2, which works.
Thanks,
Andrea
JohnC_V
Mar 01, 2018NETGEAR Employee Retired
That's not good. How about connecting it to a DHCP server just to check if it will be receiving an IP? Then run the ProSAFE utility.
- Angus73Mar 02, 2018Aspirant
JohnC_Vwrote:That's not good. How about connecting it to a DHCP server just to check if it will be receiving an IP? Then run the ProSAFE utility.
I have just set up a (linux) DHCP server on the fly. Double-checked the server config and tried it, by connecting a linux client PC, and the DHCP server works. Then I tried these steps:
- connected the switch to the DHCP server
- turned the switch on
, and the server does not show any lease granted.
then
- connected the client to the switch
, and the client regularly obtains the lease.
So it seems the device is not able to obtain a DCHP address.
Double checked the behavior with one other device also, same result. That's really weird isn't it?
