chirpa
Aug 16, 2012Luminary
Citrix XenServer 6.0.2 + ReadyNAS, XenCert results
Before I left NETGEAR, Citrix XenCert was passing for ReadyNAS. Not sure when they will get the results posted, but I want to share the test results in the meantime.
chirpa
XenServer 6.0.2 + ReadyNAS x86 4.2.21 firmware using NFS:
The XenCert command executed is:
./XenCert -b nfs -n 192.168.1.31 -e /zen
********************** Welcome to XenCert 2.0 BUILD_NUMBER='53456p' *****************
Test start time: Sat Jun 9 14:18:17 2012
Performing multipath configuration verification.
Performing control path stress tests.
SR CREATION, PBD PLUG-UNPLUG AND SR DELETION TESTS
>> These tests verify the control path by creating an SR, unplugging
and plugging the PBDs and destroying the SR in multiple iterations.
-> Iteration number: 0
Creating the SR.
PASS [Completed]
Unplugging and plugging PBDs over 10 iterations. Iteration number: 0..1..2..3..4..5..6..7..8..9..
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 1
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 2
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 3
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 4
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 5
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 6
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 7
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 8
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 9
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
SR SPACE AVAILABILITY TEST
>> This test verifies that all the free space advertised by an SR
is available and writable.
Create a new SR.
Creating the SR.
PASS [Completed]
PASS [Completed]
Create a VDI on the SR of the maximum available size.
PASS [Completed]
Create a VBD on this VDI and plug it into dom0
PASS [Completed]
Now attempt to write the maximum number of bytes on this newly plugged device.
START TIME: Sat Jun 9 14:23:33 2012
APPROXIMATE RUN TIME: 2 minutes, 50 seconds.
END TIME: Sat Jun 9 14:23:50 2012
PASS [Completed]
Destroy the SR.
PASS [Completed]
Performing pool tests to ensure consistency.
Performing functional tests.
DISCOVERING EXPORTS FROM THE SPECIFIED TARGET
>> This test probes the specified NFS target and displays the
>> various paths exported for verification by the user.
Exported Path
/c/esx
/c/zen
PASS [Completed]
VERIFY NFS TARGET PARAMETERS
>> This test attempts to mount the export path specified
>> as a local directory.
PASS [Completed]
CREATE DIRECTORY AND PERFORM FILESYSTEM IO TESTS.
>> This test creates a directory on the locally mounted path above
>> and performs some filesystem read write operations on the directory.
PASS [Completed]
REPORT FILESYSTEM TARGET SPACE PARAMETERS FOR VERIFICATION BY THE USER
- Total space : 3954902564864
- Space utilization : 2716794355712
PASS [Completed]
Performing data IO tests.
Multipath configuration verification results : PASS, Pass percentage: 100, Completed: Sat Jun 9 14:18:17 2012
Control path stress test results : PASS, Pass percentage: 100, Completed: Sat Jun 9 14:23:57 2012
Pool test results : PASS, Pass percentage: 100, Completed: Sat Jun 9 14:23:57 2012
Functional test results : PASS, Pass percentage: 100, Completed: Sat Jun 9 14:23:58 2012
Data test results : PASS, Pass percentage: 100, Completed: Sat Jun 9 14:23:58 2012
End of XenCert certification suite.
Please find the report for this test run at: /tmp/XenCert-47a01d50-e69e-445c-bdcc-dea67c57b6b6.log
Test end time: Sat Jun 9 14:23:58 2012
Execution time: 5 minutes, 40 seconds.
