chirpa
Aug 16, 2012Luminary
Citrix XenServer 6.0.2 + ReadyNAS, XenCert results
Before I left NETGEAR, Citrix XenCert was passing for ReadyNAS. Not sure when they will get the results posted, but I want to share the test results in the meantime.
chirpa
XenServer 6.0.2 + ReadyNAS x86 4.2.21 firmware using iSCSI:
The XenCert command executed is:
./XenCert -b lvmoiscsi -t 192.168.1.31,192.168.1.177 -q * -u ./blockunblockiscsipaths
********************** Welcome to XenCert 2.0 BUILD_NUMBER='53456p' *****************
Test start time: Fri Jun 8 20:01:30 2012
Performing multipath configuration verification.
CREATING SR
Creating the SR.
PASS [Completed]
PASS [Completed]
MULTIPATH AUTOMATED PATH FAILOVER TESTING
>> Multipathd enabled for LIO-ORG, FILEIO with the following config
please confirm that these settings are optimal:
device {
path_checker directio
product GNBD
vendor GNBD
rr_weight uniform
rr_min_io 1000
bindings_file /var/lib/multipath/bindings
prio_callout none
path_grouping_policy multibus
udev_dir /dev
selector round-robin 0
getuid_callout /sbin/gnbd_import -q -U /block/%n
no_path_retry fail
polling_interval 5
user_friendly_names no
failback manual
>> Starting Random Path Block and Restore Iteration test
This test will choose a random selection of upto (n -1) paths
of a total of n to block, and verify that the IO continues
i.e. the correct paths are detected as failed, within 50 seconds.
The test then verifies that after unblocking the path, it is
restored within 2 minutes.
Path Connectivity Details
IP address HBTL Path DM status Path status
192.168.1.177 32:0:0:0 active ready
192.168.1.31 31:0:0:0 active ready
Create a VDI on the SR of the maximum available size.
PASS [Completed]
Create a VBD on this VDI and plug it into dom0
PASS [Completed]
Iteration 1:
-> No manual blocking of paths.
- IO test passed. Time: 0.0377218 seconds. Data: 1MB. Throughput: 27.8 MB/s
PASS [Completed]
Iteration 2:
-> Blocking 1 paths (192.168.1.177)
- Paths failover time: 7 seconds
- Maximum IO completion time: 28.7561 seconds. Data: 1MB. Throughput: 36.5 kB/s
PASS [Completed]
-> Unblocking paths, waiting for restoration.
PASS [Completed 3 seconds]
Iteration 3:
-> Blocking 1 paths (192.168.1.31)
- Paths failover time: 15 seconds
- Maximum IO completion time: 26.7675 seconds. Data: 1MB. Throughput: 39.2 kB/s
PASS [Completed]
Iteration 4:
- Paths failover time: 5 seconds
- Maximum IO completion time: 0.0765942 seconds. Data: 1MB. Throughput: 13.7 MB/s
PASS [Completed]
PASS [Completed 4 seconds]
Iteration 5:
- Paths failover time: 4 seconds
- Maximum IO completion time: 41.8334 seconds. Data: 1MB. Throughput: 25.1 kB/s
PASS [Completed]
Iteration 6:
- Maximum IO completion time: 0.24218 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 7:
- Maximum IO completion time: 27.7951 seconds. Data: 1MB. Throughput: 37.7 kB/s
PASS [Completed]
Iteration 8:
- Maximum IO completion time: 0.0852638 seconds. Data: 1MB. Throughput: 12.3 MB/s
PASS [Completed]
Iteration 9:
- Maximum IO completion time: 28.5852 seconds. Data: 1MB. Throughput: 36.7 kB/s
PASS [Completed]
Iteration 10:
- Maximum IO completion time: 0.0744388 seconds. Data: 1MB. Throughput: 14.1 MB/s
PASS [Completed]
Iteration 11:
- Maximum IO completion time: 0.0777925 seconds. Data: 1MB. Throughput: 13.5 MB/s
PASS [Completed]
Iteration 12:
- Maximum IO completion time: 0.241365 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 13:
- Paths failover time: 13 seconds
- Maximum IO completion time: 39.5966 seconds. Data: 1MB. Throughput: 26.5 kB/s
PASS [Completed]
Iteration 14:
- Maximum IO completion time: 0.235549 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 15:
- Maximum IO completion time: 29.195 seconds. Data: 1MB. Throughput: 35.9 kB/s
PASS [Completed]
Iteration 16:
- Paths failover time: 2 seconds
- Maximum IO completion time: 27.311 seconds. Data: 1MB. Throughput: 38.4 kB/s
PASS [Completed]
Iteration 17:
- Maximum IO completion time: 26.0629 seconds. Data: 1MB. Throughput: 40.2 kB/s
PASS [Completed]
Iteration 18:
- Maximum IO completion time: 0.0737326 seconds. Data: 1MB. Throughput: 14.2 MB/s
PASS [Completed]
Iteration 19:
- Paths failover time: 12 seconds
- Maximum IO completion time: 42.8196 seconds. Data: 1MB. Throughput: 24.5 kB/s
PASS [Completed]
Iteration 20:
- Paths failover time: 18 seconds
- Maximum IO completion time: 24.8849 seconds. Data: 1MB. Throughput: 42.1 kB/s
PASS [Completed]
Iteration 21:
- Maximum IO completion time: 0.22958 seconds. Data: 1MB. Throughput: 4.6 MB/s
PASS [Completed]
Iteration 22:
- Maximum IO completion time: 0.0742206 seconds. Data: 1MB. Throughput: 14.1 MB/s
PASS [Completed]
Iteration 23:
- Maximum IO completion time: 0.0747532 seconds. Data: 1MB. Throughput: 14.0 MB/s
PASS [Completed]
Iteration 24:
- Paths failover time: 19 seconds
- Maximum IO completion time: 28.3757 seconds. Data: 1MB. Throughput: 37.0 kB/s
PASS [Completed]
Iteration 25:
- Paths failover time: 10 seconds
- Maximum IO completion time: 24.9536 seconds. Data: 1MB. Throughput: 42.0 kB/s
PASS [Completed]
Iteration 26:
- Maximum IO completion time: 0.0751539 seconds. Data: 1MB. Throughput: 14.0 MB/s
PASS [Completed]
Iteration 27:
- Maximum IO completion time: 0.0741788 seconds. Data: 1MB. Throughput: 14.1 MB/s
PASS [Completed]
Iteration 28:
- Maximum IO completion time: 0.0743842 seconds. Data: 1MB. Throughput: 14.1 MB/s
PASS [Completed]
Iteration 29:
- Paths failover time: 8 seconds
- Maximum IO completion time: 26.6949 seconds. Data: 1MB. Throughput: 39.3 kB/s
PASS [Completed]
Iteration 30:
- Paths failover time: 21 seconds
- Maximum IO completion time: 26.5764 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 31:
- Maximum IO completion time: 0.0752551 seconds. Data: 1MB. Throughput: 13.9 MB/s
PASS [Completed]
Iteration 32:
- Maximum IO completion time: 0.0846905 seconds. Data: 1MB. Throughput: 12.4 MB/s
PASS [Completed]
Iteration 33:
- Maximum IO completion time: 27.9745 seconds. Data: 1MB. Throughput: 37.5 kB/s
PASS [Completed]
Iteration 34:
- Maximum IO completion time: 0.102454 seconds. Data: 1MB. Throughput: 10.2 MB/s
PASS [Completed]
Iteration 35:
- Maximum IO completion time: 25.5142 seconds. Data: 1MB. Throughput: 41.1 kB/s
PASS [Completed]
Iteration 36:
- Paths failover time: 17 seconds
- Maximum IO completion time: 41.0635 seconds. Data: 1MB. Throughput: 25.5 kB/s
PASS [Completed]
Iteration 37:
- Maximum IO completion time: 0.076628 seconds. Data: 1MB. Throughput: 13.7 MB/s
PASS [Completed]
Iteration 38:
- Maximum IO completion time: 0.0754346 seconds. Data: 1MB. Throughput: 13.9 MB/s
PASS [Completed]
Iteration 39:
- Maximum IO completion time: 0.243631 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 40:
- Maximum IO completion time: 25.0523 seconds. Data: 1MB. Throughput: 41.9 kB/s
PASS [Completed]
Iteration 41:
- Maximum IO completion time: 0.0750705 seconds. Data: 1MB. Throughput: 14.0 MB/s
PASS [Completed]
Iteration 42:
- Maximum IO completion time: 0.0730766 seconds. Data: 1MB. Throughput: 14.3 MB/s
PASS [Completed]
Iteration 43:
- Maximum IO completion time: 0.0743456 seconds. Data: 1MB. Throughput: 14.1 MB/s
PASS [Completed]
Iteration 44:
- Maximum IO completion time: 0.0737239 seconds. Data: 1MB. Throughput: 14.2 MB/s
PASS [Completed]
Iteration 45:
- Paths failover time: 6 seconds
- Maximum IO completion time: 26.7252 seconds. Data: 1MB. Throughput: 39.2 kB/s
PASS [Completed]
Iteration 46:
- Paths failover time: 3 seconds
- Maximum IO completion time: 26.6948 seconds. Data: 1MB. Throughput: 39.3 kB/s
PASS [Completed]
Iteration 47:
- Maximum IO completion time: 0.0749554 seconds. Data: 1MB. Throughput: 14.0 MB/s
PASS [Completed]
Iteration 48:
- Maximum IO completion time: 0.238303 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 49:
- Maximum IO completion time: 0.240672 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 50:
- Maximum IO completion time: 0.0735846 seconds. Data: 1MB. Throughput: 14.2 MB/s
PASS [Completed]
Iteration 51:
- Maximum IO completion time: 0.0740482 seconds. Data: 1MB. Throughput: 14.2 MB/s
PASS [Completed]
Iteration 52:
- Paths failover time: 14 seconds
- Maximum IO completion time: 24.454 seconds. Data: 1MB. Throughput: 42.9 kB/s
PASS [Completed]
Iteration 53:
- Paths failover time: 16 seconds
- Maximum IO completion time: 28.3151 seconds. Data: 1MB. Throughput: 37.0 kB/s
PASS [Completed]
Iteration 54:
- Maximum IO completion time: 0.0985083 seconds. Data: 1MB. Throughput: 10.6 MB/s
PASS [Completed]
Iteration 55:
- Maximum IO completion time: 25.2904 seconds. Data: 1MB. Throughput: 41.5 kB/s
PASS [Completed]
Iteration 56:
- Maximum IO completion time: 27.9781 seconds. Data: 1MB. Throughput: 37.5 kB/s
PASS [Completed]
Iteration 57:
- Maximum IO completion time: 0.074708 seconds. Data: 1MB. Throughput: 14.0 MB/s
PASS [Completed]
Iteration 58:
- Maximum IO completion time: 40.5621 seconds. Data: 1MB. Throughput: 25.9 kB/s
PASS [Completed]
Iteration 59:
- Maximum IO completion time: 27.1436 seconds. Data: 1MB. Throughput: 38.6 kB/s
PASS [Completed]
Iteration 60:
- Maximum IO completion time: 25.2609 seconds. Data: 1MB. Throughput: 41.5 kB/s
PASS [Completed]
Iteration 61:
- Maximum IO completion time: 28.8859 seconds. Data: 1MB. Throughput: 36.3 kB/s
PASS [Completed]
Iteration 62:
- Paths failover time: 11 seconds
- Maximum IO completion time: 27.8054 seconds. Data: 1MB. Throughput: 37.7 kB/s
PASS [Completed]
Iteration 63:
- Maximum IO completion time: 0.0772667 seconds. Data: 1MB. Throughput: 13.6 MB/s
PASS [Completed]
Iteration 64:
- Maximum IO completion time: 40.5604 seconds. Data: 1MB. Throughput: 25.9 kB/s
PASS [Completed]
Iteration 65:
- Maximum IO completion time: 27.1305 seconds. Data: 1MB. Throughput: 38.6 kB/s
PASS [Completed]
Iteration 66:
- Maximum IO completion time: 25.187 seconds. Data: 1MB. Throughput: 41.6 kB/s
PASS [Completed]
Iteration 67:
- Maximum IO completion time: 0.0733423 seconds. Data: 1MB. Throughput: 14.3 MB/s
PASS [Completed]
Iteration 68:
- Maximum IO completion time: 0.0874226 seconds. Data: 1MB. Throughput: 12.0 MB/s
PASS [Completed]
Iteration 69:
- Maximum IO completion time: 25.0956 seconds. Data: 1MB. Throughput: 41.8 kB/s
PASS [Completed]
Iteration 70:
- Maximum IO completion time: 0.0761269 seconds. Data: 1MB. Throughput: 13.8 MB/s
PASS [Completed]
Iteration 71:
- Maximum IO completion time: 28.4591 seconds. Data: 1MB. Throughput: 36.8 kB/s
PASS [Completed]
Iteration 72:
- Maximum IO completion time: 24.8735 seconds. Data: 1MB. Throughput: 42.2 kB/s
PASS [Completed]
Iteration 73:
- Maximum IO completion time: 28.2616 seconds. Data: 1MB. Throughput: 37.1 kB/s
PASS [Completed]
Iteration 74:
- Maximum IO completion time: 0.231251 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 75:
- Maximum IO completion time: 25.3379 seconds. Data: 1MB. Throughput: 41.4 kB/s
PASS [Completed]
Iteration 76:
- Maximum IO completion time: 26.2813 seconds. Data: 1MB. Throughput: 39.9 kB/s
PASS [Completed]
Iteration 77:
- Maximum IO completion time: 28.0883 seconds. Data: 1MB. Throughput: 37.3 kB/s
PASS [Completed]
Iteration 78:
- Maximum IO completion time: 28.5525 seconds. Data: 1MB. Throughput: 36.7 kB/s
PASS [Completed]
Iteration 79:
- Maximum IO completion time: 24.4818 seconds. Data: 1MB. Throughput: 42.8 kB/s
PASS [Completed]
Iteration 80:
- Maximum IO completion time: 28.794 seconds. Data: 1MB. Throughput: 36.4 kB/s
PASS [Completed]
Iteration 81:
- Maximum IO completion time: 0.247243 seconds. Data: 1MB. Throughput: 4.2 MB/s
PASS [Completed]
Iteration 82:
- Maximum IO completion time: 24.7871 seconds. Data: 1MB. Throughput: 42.3 kB/s
PASS [Completed]
Iteration 83:
- Maximum IO completion time: 26.8697 seconds. Data: 1MB. Throughput: 39.0 kB/s
PASS [Completed]
Iteration 84:
- Maximum IO completion time: 27.2798 seconds. Data: 1MB. Throughput: 38.4 kB/s
PASS [Completed]
Iteration 85:
- Maximum IO completion time: 0.0776802 seconds. Data: 1MB. Throughput: 13.5 MB/s
PASS [Completed]
Iteration 86:
- Maximum IO completion time: 24.9846 seconds. Data: 1MB. Throughput: 42.0 kB/s
PASS [Completed]
Iteration 87:
- Maximum IO completion time: 26.6879 seconds. Data: 1MB. Throughput: 39.3 kB/s
PASS [Completed]
Iteration 88:
- Maximum IO completion time: 0.240804 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 89:
- Maximum IO completion time: 41.9142 seconds. Data: 1MB. Throughput: 25.0 kB/s
PASS [Completed]
Iteration 90:
- Maximum IO completion time: 0.0738527 seconds. Data: 1MB. Throughput: 14.2 MB/s
PASS [Completed]
Iteration 91:
- Maximum IO completion time: 0.24403 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 92:
- Maximum IO completion time: 26.2586 seconds. Data: 1MB. Throughput: 39.9 kB/s
PASS [Completed]
Iteration 93:
- Maximum IO completion time: 0.0774823 seconds. Data: 1MB. Throughput: 13.5 MB/s
PASS [Completed]
Iteration 94:
- Maximum IO completion time: 0.0767763 seconds. Data: 1MB. Throughput: 13.7 MB/s
PASS [Completed]
Iteration 95:
- Maximum IO completion time: 0.0755982 seconds. Data: 1MB. Throughput: 13.9 MB/s
PASS [Completed]
Iteration 96:
- Maximum IO completion time: 0.076386 seconds. Data: 1MB. Throughput: 13.7 MB/s
PASS [Completed]
Iteration 97:
- Maximum IO completion time: 29.113 seconds. Data: 1MB. Throughput: 36.0 kB/s
PASS [Completed]
Iteration 98:
- Maximum IO completion time: 28.5584 seconds. Data: 1MB. Throughput: 36.7 kB/s
PASS [Completed]
Iteration 99:
- Maximum IO completion time: 0.0756202 seconds. Data: 1MB. Throughput: 13.9 MB/s
PASS [Completed]
- Test succeeded.
Destroy the SR.
PASS [Completed]
Performing control path stress tests.
SR CREATION, PBD PLUG-UNPLUG AND SR DELETION TESTS
>> These tests verify the control path by creating an SR, unplugging
and plugging the PBDs and destroying the SR in multiple iterations.
-> Iteration number: 0
Creating the SR.
PASS [Completed]
Unplugging and plugging PBDs over 10 iterations. Iteration number: 0..1..2..3..4..5..6..7..8..9..
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 1
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 2
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 3
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 4
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 5
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 6
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 7
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 8
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 9
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
SR SPACE AVAILABILITY TEST
>> This test verifies that all the free space advertised by an SR
is available and writable.
Create a new SR.
Creating the SR.
PASS [Completed]
PASS [Completed]
PASS [Completed]
PASS [Completed]
Now attempt to write the maximum number of bytes on this newly plugged device.
START TIME: Fri Jun 8 21:48:30 2012
APPROXIMATE RUN TIME: 2 minutes, 28 seconds.
END TIME: Fri Jun 8 21:49:09 2012
PASS [Completed]
Destroy the SR.
PASS [Completed]
Performing pool tests to ensure consistency.
POOL CONSISTENCY TESTS.
>> This test creates shared SRs and verifies that PBD records
display the same number of paths for each host in the pool.
-> Enabling multipathing on each host in the pool.
PASS [Completed]
-> Creating shared SR.
Creating the SR.
PASS [Completed]
-> Checking paths reflected on PBDs for each host.
Host [Active, Passive]
OpaqueRef:652eec51-0fff-1d1e-e9c3-05277d4f766c [2, 2]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Disable multipathing on hosts.
Performing functional tests.
INITIALIZING SCSI DATA PATH LAYER
PASS [Completed]
DISCOVERING ADVERTISED SESSION TARGETS
IQN Session Target
iqn.2011-12.DG-LAB-ESX-3200:xen 192.168.1.31:3260
iqn.2011-12.DG-LAB-ESX-3200:xen 192.168.1.177:3260
PASS [Completed]
REPORT LUNS EXPOSED
>> This test logs on to all the advertised target and IQN combinations
and discovers the LUNs exposed by each including information
like the LUN ID, SCSI ID and the size of each LUN.
This test also verifies that all the sessions from the same IQN
expose the same number of LUNs and the same LUNs.
PORTAL LUN SCSI-ID Size(MiB)
192.168.1.31:3260 0 524e333031593830303036332d303032 30720
192.168.1.177:3260 0 524e333031593830303036332d303032 30720
PASS [Completed]
DISK IO TESTS
>> This tests execute a disk IO test against each available LUN to verify
that they are writeable and there is no apparent disk corruption.
the tests attempt to write to the LUN over each available path and
reports the number of writable paths to each LUN.
START TIME: Fri Jun 8 21:51:54 2012
APPROXIMATE RUN TIME: 49 minutes, 42 seconds.
- Testing LUN with SCSI ID 524e333031593830303036332d303032
Path num: 1. Device: /dev/sdb
PASS [Completed]
Path num: 2. Device: /dev/sdc
PASS [Completed]
SCSI ID: 524e333031593830303036332d303032 Total paths: 2. Writable paths: 2.
PASS [Completed]
END TIME: Fri Jun 8 22:59:38 2012
Performing data IO tests.
Multipath configuration verification results : PASS, Pass percentage: 100, Completed: Fri Jun 8 21:01:32 2012
Control path stress test results : PASS, Pass percentage: 100, Completed: Fri Jun 8 21:49:40 2012
Pool test results : PASS, Pass percentage: 100, Completed: Fri Jun 8 21:50:54 2012
Functional test results : PASS, Pass percentage: 100, Completed: Fri Jun 8 22:59:39 2012
Data test results : PASS, Pass percentage: 100, Completed: Fri Jun 8 22:59:39 2012
End of XenCert certification suite.
Please find the report for this test run at: /tmp/XenCert-2eecd1d3-89fa-423f-9177-9f5492d2a954.log
Test end time: Fri Jun 8 22:59:39 2012
Execution time: 2 hours, 58 minutes, 9 seconds.
