chirpa
Aug 16, 2012Luminary
Citrix XenServer 6.0.2 + ReadyNAS, XenCert results
Before I left NETGEAR, Citrix XenCert was passing for ReadyNAS. Not sure when they will get the results posted, but I want to share the test results in the meantime.
chirpa
XenServer 6.0.2 + ReadyDATA 1.0.0 firmware using iSCSI:
The XenCert command executed is:
./XenCert -b lvmoiscsi -t 192.168.1.41,192.168.1.156 -q * -u ./blockunblockiscsipaths
********************** Welcome to XenCert 2.0 BUILD_NUMBER='53456p' *****************
Test start time: Mon Jun 11 15:59:00 2012
Performing multipath configuration verification.
CREATING SR
Creating the SR.
PASS [Completed]
PASS [Completed]
MULTIPATH AUTOMATED PATH FAILOVER TESTING
>> Multipathd enabled for NETGEAR, ReadyDATA with the following config
please confirm that these settings are optimal:
device {
path_checker directio
product GNBD
vendor GNBD
rr_weight uniform
rr_min_io 1000
bindings_file /var/lib/multipath/bindings
prio_callout none
path_grouping_policy multibus
udev_dir /dev
selector round-robin 0
getuid_callout /sbin/gnbd_import -q -U /block/%n
no_path_retry fail
polling_interval 5
user_friendly_names no
failback manual
>> Starting Random Path Block and Restore Iteration test
This test will choose a random selection of upto (n -1) paths
of a total of n to block, and verify that the IO continues
i.e. the correct paths are detected as failed, within 50 seconds.
The test then verifies that after unblocking the path, it is
restored within 2 minutes.
Path Connectivity Details
IP address HBTL Path DM status Path status
192.168.1.156 392:0:0:0 active ready
192.168.1.41 391:0:0:0 active ready
Create a VDI on the SR of the maximum available size.
PASS [Completed]
Create a VBD on this VDI and plug it into dom0
PASS [Completed]
Iteration 1:
-> No manual blocking of paths.
- IO test passed. Time: 0.028273 seconds. Data: 1MB. Throughput: 37.1 MB/s
PASS [Completed]
Iteration 2:
-> Blocking 1 paths (192.168.1.156)
- Paths failover time: 14 seconds
- Maximum IO completion time: 32.4192 seconds. Data: 1MB. Throughput: 32.3 kB/s
PASS [Completed]
-> Unblocking paths, waiting for restoration.
PASS [Completed 4 seconds]
Iteration 3:
-> Blocking 1 paths (192.168.1.41)
- Maximum IO completion time: 26.3222 seconds. Data: 1MB. Throughput: 39.8 kB/s
PASS [Completed]
PASS [Completed 3 seconds]
Iteration 4:
- Paths failover time: 5 seconds
- Maximum IO completion time: 0.0955376 seconds. Data: 1MB. Throughput: 11.0 MB/s
PASS [Completed]
Iteration 5:
- Paths failover time: 6 seconds
- Maximum IO completion time: 27.562 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 6:
- Paths failover time: 3 seconds
- Maximum IO completion time: 26.592 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 7:
- Maximum IO completion time: 26.5789 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 8:
- Paths failover time: 4 seconds
- Maximum IO completion time: 27.5591 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 9:
- Maximum IO completion time: 26.5595 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 10:
- Maximum IO completion time: 26.3958 seconds. Data: 1MB. Throughput: 39.7 kB/s
PASS [Completed]
Iteration 11:
- Maximum IO completion time: 0.337754 seconds. Data: 1MB. Throughput: 3.1 MB/s
PASS [Completed]
Iteration 12:
- Paths failover time: 16 seconds
- Maximum IO completion time: 27.6036 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 13:
- Maximum IO completion time: 0.0985148 seconds. Data: 1MB. Throughput: 10.6 MB/s
PASS [Completed]
Iteration 14:
- Maximum IO completion time: 26.5856 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 15:
- Paths failover time: 7 seconds
- Maximum IO completion time: 27.642 seconds. Data: 1MB. Throughput: 37.9 kB/s
PASS [Completed]
Iteration 16:
- Maximum IO completion time: 0.231946 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 17:
- Maximum IO completion time: 0.236418 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 18:
- Paths failover time: 20 seconds
- Maximum IO completion time: 31.5963 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 19:
- Paths failover time: 9 seconds
- Maximum IO completion time: 26.5275 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 20:
- Maximum IO completion time: 0.300448 seconds. Data: 1MB. Throughput: 3.5 MB/s
PASS [Completed]
Iteration 21:
- Maximum IO completion time: 0.252909 seconds. Data: 1MB. Throughput: 4.1 MB/s
PASS [Completed]
Iteration 22:
- Paths failover time: 19 seconds
- Maximum IO completion time: 31.5709 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 23:
- Maximum IO completion time: 0.167182 seconds. Data: 1MB. Throughput: 6.3 MB/s
PASS [Completed]
Iteration 24:
- Maximum IO completion time: 0.240962 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 25:
- Paths failover time: 8 seconds
- Maximum IO completion time: 26.6094 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 26:
- Paths failover time: 21 seconds
- Maximum IO completion time: 31.555 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 27:
- Maximum IO completion time: 27.5763 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 28:
- Maximum IO completion time: 32.584 seconds. Data: 1MB. Throughput: 32.2 kB/s
PASS [Completed]
Iteration 29:
- Maximum IO completion time: 0.254783 seconds. Data: 1MB. Throughput: 4.1 MB/s
PASS [Completed]
Iteration 30:
- Maximum IO completion time: 0.234106 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 31:
- Maximum IO completion time: 0.238797 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 32:
- Maximum IO completion time: 0.209979 seconds. Data: 1MB. Throughput: 5.0 MB/s
PASS [Completed]
Iteration 33:
- Maximum IO completion time: 26.349 seconds. Data: 1MB. Throughput: 39.8 kB/s
PASS [Completed]
Iteration 34:
- Paths failover time: 2 seconds
- Maximum IO completion time: 26.4914 seconds. Data: 1MB. Throughput: 39.6 kB/s
PASS [Completed]
Iteration 35:
- Maximum IO completion time: 27.6476 seconds. Data: 1MB. Throughput: 37.9 kB/s
PASS [Completed]
Iteration 36:
- Maximum IO completion time: 31.576 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 37:
- Maximum IO completion time: 26.588 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 38:
- Maximum IO completion time: 31.5237 seconds. Data: 1MB. Throughput: 33.3 kB/s
PASS [Completed]
Iteration 39:
- Maximum IO completion time: 26.6096 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 40:
- Maximum IO completion time: 0.0937562 seconds. Data: 1MB. Throughput: 11.2 MB/s
PASS [Completed]
Iteration 41:
- Paths failover time: 11 seconds
- Maximum IO completion time: 26.5359 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 42:
- Maximum IO completion time: 0.228392 seconds. Data: 1MB. Throughput: 4.6 MB/s
PASS [Completed]
Iteration 43:
- Maximum IO completion time: 0.231985 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 44:
- Paths failover time: 17 seconds
- Maximum IO completion time: 26.5366 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 45:
- Paths failover time: 13 seconds
- Maximum IO completion time: 27.5747 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 46:
- Maximum IO completion time: 0.231954 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 47:
- Maximum IO completion time: 26.5402 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 48:
- Maximum IO completion time: 0.238636 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 49:
- Maximum IO completion time: 26.5737 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 50:
- Maximum IO completion time: 0.0945942 seconds. Data: 1MB. Throughput: 11.1 MB/s
PASS [Completed]
Iteration 51:
- Maximum IO completion time: 0.235046 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 52:
- Maximum IO completion time: 27.6675 seconds. Data: 1MB. Throughput: 37.9 kB/s
PASS [Completed]
Iteration 53:
- Maximum IO completion time: 0.235481 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 54:
- Maximum IO completion time: 31.5242 seconds. Data: 1MB. Throughput: 33.3 kB/s
PASS [Completed]
Iteration 55:
- Maximum IO completion time: 26.5484 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 56:
- Maximum IO completion time: 0.23571 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 57:
- Paths failover time: 10 seconds
- Maximum IO completion time: 26.5487 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 58:
- Maximum IO completion time: 0.232522 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 59:
- Maximum IO completion time: 27.6237 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 60:
- Maximum IO completion time: 0.191189 seconds. Data: 1MB. Throughput: 5.5 MB/s
PASS [Completed]
Iteration 61:
- Maximum IO completion time: 0.301885 seconds. Data: 1MB. Throughput: 3.5 MB/s
PASS [Completed]
Iteration 62:
- Maximum IO completion time: 0.232049 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 63:
- Maximum IO completion time: 0.158751 seconds. Data: 1MB. Throughput: 6.6 MB/s
PASS [Completed]
Iteration 64:
- Maximum IO completion time: 0.248361 seconds. Data: 1MB. Throughput: 4.2 MB/s
PASS [Completed]
Iteration 65:
- Maximum IO completion time: 0.231279 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 66:
- Maximum IO completion time: 26.5753 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 67:
- Maximum IO completion time: 0.122896 seconds. Data: 1MB. Throughput: 8.5 MB/s
PASS [Completed]
Iteration 68:
- Maximum IO completion time: 26.5657 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 69:
- Maximum IO completion time: 0.268887 seconds. Data: 1MB. Throughput: 3.9 MB/s
PASS [Completed]
Iteration 70:
- Maximum IO completion time: 0.23447 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 71:
- Maximum IO completion time: 0.237296 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 72:
- Maximum IO completion time: 0.240026 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 73:
- Maximum IO completion time: 0.0948174 seconds. Data: 1MB. Throughput: 11.1 MB/s
PASS [Completed]
Iteration 74:
- Maximum IO completion time: 0.235465 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 75:
- Maximum IO completion time: 0.0942626 seconds. Data: 1MB. Throughput: 11.1 MB/s
PASS [Completed]
Iteration 76:
- Maximum IO completion time: 26.536 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 77:
- Maximum IO completion time: 31.5745 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 78:
- Maximum IO completion time: 26.613 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 79:
- Maximum IO completion time: 0.23965 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 80:
- Maximum IO completion time: 0.234819 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 81:
- Maximum IO completion time: 31.5718 seconds. Data: 1MB. Throughput: 33.2 kB/s
PASS [Completed]
Iteration 82:
- Maximum IO completion time: 26.5877 seconds. Data: 1MB. Throughput: 39.4 kB/s
PASS [Completed]
Iteration 83:
- Maximum IO completion time: 0.235963 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 84:
- Maximum IO completion time: 0.232888 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 85:
- Maximum IO completion time: 31.6439 seconds. Data: 1MB. Throughput: 33.1 kB/s
PASS [Completed]
Iteration 86:
- Maximum IO completion time: 26.5552 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 87:
- Maximum IO completion time: 0.163284 seconds. Data: 1MB. Throughput: 6.4 MB/s
PASS [Completed]
Iteration 88:
- Maximum IO completion time: 26.5727 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 89:
- Maximum IO completion time: 32.5661 seconds. Data: 1MB. Throughput: 32.2 kB/s
PASS [Completed]
Iteration 90:
- Maximum IO completion time: 0.120574 seconds. Data: 1MB. Throughput: 8.7 MB/s
PASS [Completed]
Iteration 91:
- Maximum IO completion time: 0.230487 seconds. Data: 1MB. Throughput: 4.5 MB/s
PASS [Completed]
Iteration 92:
- Maximum IO completion time: 0.236938 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 93:
- Maximum IO completion time: 0.0967387 seconds. Data: 1MB. Throughput: 10.8 MB/s
PASS [Completed]
Iteration 94:
- Maximum IO completion time: 0.237506 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
Iteration 95:
- Paths failover time: 15 seconds
- Maximum IO completion time: 26.571 seconds. Data: 1MB. Throughput: 39.5 kB/s
PASS [Completed]
Iteration 96:
- Maximum IO completion time: 26.3836 seconds. Data: 1MB. Throughput: 39.7 kB/s
PASS [Completed]
Iteration 97:
- Maximum IO completion time: 0.150968 seconds. Data: 1MB. Throughput: 6.9 MB/s
PASS [Completed]
Iteration 98:
- Maximum IO completion time: 27.5584 seconds. Data: 1MB. Throughput: 38.0 kB/s
PASS [Completed]
Iteration 99:
- Maximum IO completion time: 0.236144 seconds. Data: 1MB. Throughput: 4.4 MB/s
PASS [Completed]
- Test succeeded.
Destroy the SR.
PASS [Completed]
Performing control path stress tests.
SR CREATION, PBD PLUG-UNPLUG AND SR DELETION TESTS
>> These tests verify the control path by creating an SR, unplugging
and plugging the PBDs and destroying the SR in multiple iterations.
-> Iteration number: 0
Creating the SR.
PASS [Completed]
Unplugging and plugging PBDs over 10 iterations. Iteration number: 0..1..2..3..4..5..6..7..8..9..
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 1
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 2
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 3
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 4
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 5
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 6
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 7
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 8
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 9
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
SR SPACE AVAILABILITY TEST
>> This test verifies that all the free space advertised by an SR
is available and writable.
Create a new SR.
Creating the SR.
PASS [Completed]
PASS [Completed]
PASS [Completed]
PASS [Completed]
Now attempt to write the maximum number of bytes on this newly plugged device.
START TIME: Mon Jun 11 17:51:02 2012
APPROXIMATE RUN TIME: 3 minutes, 50 seconds.
END TIME: Mon Jun 11 17:51:39 2012
PASS [Completed]
Destroy the SR.
PASS [Completed]
Performing pool tests to ensure consistency.
POOL CONSISTENCY TESTS.
>> This test creates shared SRs and verifies that PBD records
display the same number of paths for each host in the pool.
-> Enabling multipathing on each host in the pool.
PASS [Completed]
-> Creating shared SR.
Creating the SR.
PASS [Completed]
-> Checking paths reflected on PBDs for each host.
Host [Active, Passive]
OpaqueRef:652eec51-0fff-1d1e-e9c3-05277d4f766c [2, 2]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Disable multipathing on hosts.
Performing functional tests.
INITIALIZING SCSI DATA PATH LAYER
PASS [Completed]
DISCOVERING ADVERTISED SESSION TARGETS
IQN Session Target
iqn.1994-11.com.dg-lab-5200:xentest 192.168.1.41:3260
iqn.1994-11.com.dg-lab-5200:xentest 192.168.1.156:3260
PASS [Completed]
REPORT LUNS EXPOSED
>> This test logs on to all the advertised target and IQN combinations
and discovers the LUNs exposed by each including information
like the LUN ID, SCSI ID and the size of each LUN.
This test also verifies that all the sessions from the same IQN
expose the same number of LUNs and the same LUNs.
WARNING: No LUNs reported by portal 192.168.1.41:3260 for iqn iqn.1994-11.com.dg-lab-5200:xentest. Exception: - No LUNs found!
WARNING: No LUNs reported by portal 192.168.1.156:3260 for iqn iqn.1994-11.com.dg-lab-5200:xentest. Exception: - No LUNs found!
PASS [Completed]
DISK IO TESTS
>> This tests execute a disk IO test against each available LUN to verify
that they are writeable and there is no apparent disk corruption.
the tests attempt to write to the LUN over each available path and
reports the number of writable paths to each LUN.
START TIME: Mon Jun 11 17:53:41 2012
END TIME: Mon Jun 11 17:53:41 2012
Performing data IO tests.
Multipath configuration verification results : PASS, Pass percentage: 100, Completed: Mon Jun 11 17:02:46 2012
Control path stress test results : PASS, Pass percentage: 100, Completed: Mon Jun 11 17:52:11 2012
Pool test results : PASS, Pass percentage: 100, Completed: Mon Jun 11 17:53:31 2012
Functional test results : PASS, Pass percentage: 100, Completed: Mon Jun 11 17:53:42 2012
Data test results : PASS, Pass percentage: 100, Completed: Mon Jun 11 17:53:42 2012
End of XenCert certification suite.
Please find the report for this test run at: /tmp/XenCert-49d65035-e063-42a8-b329-5cce06cc25b1.log
Test end time: Mon Jun 11 17:53:42 2012
Execution time: 1 hours, 54 minutes, 42 seconds.
