chirpa
Aug 16, 2012Luminary
Citrix XenServer 6.0.2 + ReadyNAS, XenCert results
Before I left NETGEAR, Citrix XenCert was passing for ReadyNAS. Not sure when they will get the results posted, but I want to share the test results in the meantime.
chirpa
[OLD] XenServer 5.6 + ReadyNAS x86 4.2.16 firmware using iSCSI:
The XenCert command executed is:
./XenCert -b lvmoiscsi -t 192.168.1.109,192.168.1.102 -q * -u /root/XenCert2.0/blockunblockiscsipaths-ntgr
********************** Welcome to XenCert 2.0 build 4 *****************
Test start time: Mon Apr 4 10:12:50 2011
Performing multipath configuration verification.
CREATING SR
Creating the SR.
PASS [Completed]
PASS [Completed]
MULTIPATH AUTOMATED PATH FAILOVER TESTING
>> Multipathd enabled for LIO-ORG, FILEIO with the following config
please confirm that these settings are optimal:
device {
path_checker directio
product GNBD
vendor GNBD
rr_weight uniform
rr_min_io 1000
bindings_file /var/lib/multipath/bindings
prio_callout none
path_grouping_policy multibus
udev_dir /dev
selector round-robin 0
getuid_callout /sbin/gnbd_import -q -U /block/%n
no_path_retry fail
polling_interval 5
user_friendly_names no
failback manual
>> Starting Random Path Block and Restore Iteration test
This test will choose a random selection of upto (n -1) paths
of a total of n to block, and verify that the IO continues
i.e. the correct paths are detected as failed, within 50 seconds.
The test then verifies that after unblocking the path, it is
restored within 2 minutes.
Path Connectivity Details
IP address HBTL Path DM status Path status
39205:0:0:0 active ready
39204:0:0:0 active ready
Create a VDI on the SR of the maximum available size.
PASS [Completed]
Create a VBD on this VDI and plug it into dom0
PASS [Completed]
Iteration 1:
-> No manual blocking of paths.
- IO test passed. Time: 0.0380189 seconds. Data: 1MB. Throughput: 27.6 MB/s
PASS [Completed]
Iteration 2:
-> Blocking 1 paths (192.168.1.102)
- Paths failover time: 16 seconds
- Maximum IO completion time: 0.107291 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
-> Unblocking paths, waiting for restoration.
PASS [Completed 3 seconds]
Iteration 3:
- Paths failover time: 5 seconds
- Maximum IO completion time: 0.114985 seconds. Data: 1MB. Throughput: 9.1 MB/s
PASS [Completed]
Iteration 4:
-> Blocking 1 paths (192.168.1.109)
- Maximum IO completion time: 36.4934 seconds. Data: 1MB. Throughput: 28.7 kB/s
PASS [Completed]
PASS [Completed 10 seconds]
Iteration 5:
- Maximum IO completion time: 0.100719 seconds. Data: 1MB. Throughput: 10.4 MB/s
PASS [Completed]
Iteration 6:
- Paths failover time: 15 seconds
- Maximum IO completion time: 36.2737 seconds. Data: 1MB. Throughput: 28.9 kB/s
PASS [Completed]
Iteration 7:
- Maximum IO completion time: 0.285278 seconds. Data: 1MB. Throughput: 3.7 MB/s
PASS [Completed]
PASS [Completed 8 seconds]
Iteration 8:
- Paths failover time: 20 seconds
- Maximum IO completion time: 37.9771 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 9:
- Paths failover time: 10 seconds
- Maximum IO completion time: 36.331 seconds. Data: 1MB. Throughput: 28.9 kB/s
PASS [Completed]
Iteration 10:
- Maximum IO completion time: 38.0923 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 11:
- Maximum IO completion time: 0.28577 seconds. Data: 1MB. Throughput: 3.7 MB/s
PASS [Completed]
Iteration 12:
- Maximum IO completion time: 38.0702 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 13:
- Maximum IO completion time: 0.104771 seconds. Data: 1MB. Throughput: 10.0 MB/s
PASS [Completed]
Iteration 14:
- Maximum IO completion time: 0.250529 seconds. Data: 1MB. Throughput: 4.2 MB/s
PASS [Completed]
Iteration 15:
- Maximum IO completion time: 34.9852 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 16:
- Maximum IO completion time: 38.6031 seconds. Data: 1MB. Throughput: 27.2 kB/s
PASS [Completed]
PASS [Completed 5 seconds]
Iteration 17:
- Maximum IO completion time: 0.0791838 seconds. Data: 1MB. Throughput: 13.2 MB/s
PASS [Completed]
Iteration 18:
- Maximum IO completion time: 36.6421 seconds. Data: 1MB. Throughput: 28.6 kB/s
PASS [Completed]
Iteration 19:
- Maximum IO completion time: 36.4638 seconds. Data: 1MB. Throughput: 28.8 kB/s
PASS [Completed]
Iteration 20:
- Maximum IO completion time: 34.8373 seconds. Data: 1MB. Throughput: 30.1 kB/s
PASS [Completed]
Iteration 21:
- Maximum IO completion time: 0.107127 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 22:
- Maximum IO completion time: 35.5608 seconds. Data: 1MB. Throughput: 29.5 kB/s
PASS [Completed]
Iteration 23:
- Maximum IO completion time: 38.2846 seconds. Data: 1MB. Throughput: 27.4 kB/s
PASS [Completed]
Iteration 24:
- Maximum IO completion time: 38.0565 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 25:
- Maximum IO completion time: 38.0154 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 26:
- Maximum IO completion time: 0.117089 seconds. Data: 1MB. Throughput: 9.0 MB/s
PASS [Completed]
Iteration 27:
- Maximum IO completion time: 37.3349 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 28:
- Maximum IO completion time: 0.11392 seconds. Data: 1MB. Throughput: 9.2 MB/s
PASS [Completed]
Iteration 29:
- Maximum IO completion time: 0.108045 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 30:
- Maximum IO completion time: 0.107915 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 31:
- Maximum IO completion time: 0.106904 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 32:
- Maximum IO completion time: 34.9975 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 33:
- Maximum IO completion time: 0.101925 seconds. Data: 1MB. Throughput: 10.3 MB/s
PASS [Completed]
Iteration 34:
- Maximum IO completion time: 37.8753 seconds. Data: 1MB. Throughput: 27.7 kB/s
PASS [Completed]
Iteration 35:
- Maximum IO completion time: 0.113605 seconds. Data: 1MB. Throughput: 9.2 MB/s
PASS [Completed]
Iteration 36:
- Maximum IO completion time: 0.0530714 seconds. Data: 1MB. Throughput: 19.8 MB/s
PASS [Completed]
Iteration 37:
- Maximum IO completion time: 38.0155 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 38:
- Maximum IO completion time: 35.0448 seconds. Data: 1MB. Throughput: 29.9 kB/s
PASS [Completed]
Iteration 39:
- Maximum IO completion time: 0.104249 seconds. Data: 1MB. Throughput: 10.1 MB/s
PASS [Completed]
Iteration 40:
- Maximum IO completion time: 35.4727 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 41:
- Maximum IO completion time: 38.1571 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 42:
- Maximum IO completion time: 0.109305 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 43:
- Maximum IO completion time: 0.107005 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 44:
- Maximum IO completion time: 0.105623 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
PASS [Completed 4 seconds]
Iteration 45:
- Maximum IO completion time: 0.104611 seconds. Data: 1MB. Throughput: 10.0 MB/s
PASS [Completed]
Iteration 46:
- Maximum IO completion time: 0.104712 seconds. Data: 1MB. Throughput: 10.0 MB/s
PASS [Completed]
Iteration 47:
- Maximum IO completion time: 0.109653 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 48:
- Maximum IO completion time: 0.107677 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 49:
- Maximum IO completion time: 0.106998 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 50:
- Maximum IO completion time: 0.110889 seconds. Data: 1MB. Throughput: 9.5 MB/s
PASS [Completed]
Iteration 51:
- Maximum IO completion time: 0.107572 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 52:
- Maximum IO completion time: 0.203931 seconds. Data: 1MB. Throughput: 5.1 MB/s
PASS [Completed]
Iteration 53:
- Maximum IO completion time: 0.0754768 seconds. Data: 1MB. Throughput: 13.9 MB/s
PASS [Completed]
Iteration 54:
- Maximum IO completion time: 0.105816 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 55:
- Paths failover time: 14 seconds
- Maximum IO completion time: 38.033 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 56:
- Maximum IO completion time: 0.108615 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 57:
- Paths failover time: 6 seconds
- Maximum IO completion time: 34.9806 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 58:
PASS [Completed]
Iteration 59:
- Paths failover time: 9 seconds
- Maximum IO completion time: 37.0427 seconds. Data: 1MB. Throughput: 28.3 kB/s
PASS [Completed]
Iteration 60:
- Maximum IO completion time: 0.107846 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 61:
- Maximum IO completion time: 0.108773 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 62:
- Paths failover time: 21 seconds
- Maximum IO completion time: 39.0623 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 63:
- Maximum IO completion time: 0.161553 seconds. Data: 1MB. Throughput: 6.5 MB/s
PASS [Completed]
Iteration 64:
- Paths failover time: 4 seconds
- Maximum IO completion time: 39.0365 seconds. Data: 1MB. Throughput: 26.9 kB/s
PASS [Completed]
Iteration 65:
- Paths failover time: 11 seconds
- Maximum IO completion time: 34.354 seconds. Data: 1MB. Throughput: 30.5 kB/s
PASS [Completed]
Iteration 66:
- Maximum IO completion time: 0.285646 seconds. Data: 1MB. Throughput: 3.7 MB/s
PASS [Completed]
Iteration 67:
- Maximum IO completion time: 0.242245 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 68:
- Paths failover time: 19 seconds
- Maximum IO completion time: 36.9846 seconds. Data: 1MB. Throughput: 28.4 kB/s
PASS [Completed]
Iteration 69:
- Maximum IO completion time: 36.9035 seconds. Data: 1MB. Throughput: 28.4 kB/s
PASS [Completed]
Iteration 70:
- Maximum IO completion time: 0.113225 seconds. Data: 1MB. Throughput: 9.3 MB/s
PASS [Completed]
Iteration 71:
- Maximum IO completion time: 0.107129 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 72:
- Maximum IO completion time: 0.114225 seconds. Data: 1MB. Throughput: 9.2 MB/s
PASS [Completed]
Iteration 73:
- Maximum IO completion time: 0.109173 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 74:
- Maximum IO completion time: 0.116152 seconds. Data: 1MB. Throughput: 9.0 MB/s
PASS [Completed]
Iteration 75:
- Maximum IO completion time: 0.111692 seconds. Data: 1MB. Throughput: 9.4 MB/s
PASS [Completed]
Iteration 76:
- Maximum IO completion time: 0.107822 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 77:
- Maximum IO completion time: 36.5804 seconds. Data: 1MB. Throughput: 28.7 kB/s
PASS [Completed]
Iteration 78:
- Maximum IO completion time: 39.1419 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 79:
- Maximum IO completion time: 37.0549 seconds. Data: 1MB. Throughput: 28.3 kB/s
PASS [Completed]
Iteration 80:
- Maximum IO completion time: 0.108798 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 81:
- Maximum IO completion time: 0.0634878 seconds. Data: 1MB. Throughput: 16.5 MB/s
PASS [Completed]
Iteration 82:
- Maximum IO completion time: 39.0828 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 83:
- Maximum IO completion time: 39.2528 seconds. Data: 1MB. Throughput: 26.7 kB/s
PASS [Completed]
Iteration 84:
- Maximum IO completion time: 37.2323 seconds. Data: 1MB. Throughput: 28.2 kB/s
PASS [Completed]
Iteration 85:
- Maximum IO completion time: 0.241115 seconds. Data: 1MB. Throughput: 4.3 MB/s
PASS [Completed]
Iteration 86:
- Maximum IO completion time: 36.979 seconds. Data: 1MB. Throughput: 28.4 kB/s
PASS [Completed]
Iteration 87:
- Maximum IO completion time: 0.102899 seconds. Data: 1MB. Throughput: 10.2 MB/s
PASS [Completed]
Iteration 88:
- Maximum IO completion time: 39.1136 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 89:
- Maximum IO completion time: 0.107931 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 90:
- Maximum IO completion time: 0.082987 seconds. Data: 1MB. Throughput: 12.6 MB/s
PASS [Completed]
Iteration 91:
- Maximum IO completion time: 38.0044 seconds. Data: 1MB. Throughput: 27.6 kB/s
PASS [Completed]
Iteration 92:
- Maximum IO completion time: 0.107991 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 93:
- Maximum IO completion time: 0.106174 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 94:
- Maximum IO completion time: 0.107505 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 95:
- Maximum IO completion time: 38.3445 seconds. Data: 1MB. Throughput: 27.3 kB/s
PASS [Completed]
Iteration 96:
- Maximum IO completion time: 35.1795 seconds. Data: 1MB. Throughput: 29.8 kB/s
PASS [Completed]
Iteration 97:
- Maximum IO completion time: 0.106584 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 98:
- Maximum IO completion time: 35.4144 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 99:
- Maximum IO completion time: 0.107057 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
- Test succeeded.
Destroy the SR.
PASS [Completed]
Performing control path stress tests.
SR CREATION, PBD PLUG-UNPLUG AND SR DELETION TESTS
>> These tests verify the control path by creating an SR, unplugging
and plugging the PBDs and destroying the SR in multiple iterations.
-> Iteration number: 0
Creating the SR.
PASS [Completed]
Unplugging and plugging PBDs over 10 iterations. Iteration number: 0..1..2..3..4..5..6..7..8..9..
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 1
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 2
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 3
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 4
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 5
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 6
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 7
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 8
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 9
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
SR SPACE AVAILABILITY TEST
>> This test verifies that all the free space advertised by an SR
is available and writable.
Create a new SR.
Creating the SR.
PASS [Completed]
PASS [Completed]
PASS [Completed]
PASS [Completed]
Now attempt to write the maximum number of bytes on this newly plugged device.
START TIME: Mon Apr 4 12:00:38 2011
APPROXIMATE RUN TIME: 2 hours, 50 minutes, 14 seconds.
END TIME: Mon Apr 4 12:40:03 2011
PASS [Completed]
Destroy the SR.
PASS [Completed]
Performing pool tests to ensure consistency.
POOL CONSISTENCY TESTS.
>> This test creates shared SRs and verifies that PBD records
display the same number of paths for each host in the pool.
-> Enabling multipathing on each host in the pool.
PASS [Completed]
-> Creating shared SR.
Creating the SR.
PASS [Completed]
-> Checking paths reflected on PBDs for each host.
Host [Active, Passive]
OpaqueRef:b19d017e-fa00-1f0f-e1cc-16a7036b5830 [2, 2]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Disable multipathing on hosts.
Performing functional tests.
INITIALIZING SCSI DATA PATH LAYER
PASS [Completed]
DISCOVERING ADVERTISED SESSION TARGETS
IQN Session Target
iqn.2011-02.DG-LAB-ZEN-2100:zen-a 192.168.1.102:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-b 192.168.1.109:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-a 192.168.1.109:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-b 192.168.1.102:3260
PASS [Completed]
REPORT LUNS EXPOSED
>> This test logs on to all the advertised target and IQN combinations
and discovers the LUNs exposed by each including information
like the LUN ID, SCSI ID and the size of each LUN.
This test also verifies that all the sessions from the same IQN
expose the same number of LUNs and the same LUNs.
PORTAL LUN SCSI-ID Size(MiB)
192.168.1.102:3260 0 524e2d303031 40960
192.168.1.109:3260 0 524e2d303032 40960
192.168.1.109:3260 0 524e2d303031 40960
192.168.1.102:3260 0 524e2d303032 40960
PASS [Completed]
DISK IO TESTS
>> This tests execute a disk IO test against each available LUN to verify
that they are writeable and there is no apparent disk corruption.
the tests attempt to write to the LUN over each available path and
reports the number of writable paths to each LUN.
START TIME: Mon Apr 4 12:43:55 2011
APPROXIMATE RUN TIME: 2 hours, 40 minutes, 30 seconds.
- Testing LUN with SCSI ID 524e2d303032
Path num: 1. Device: /dev/sdc
PASS [Completed]
Path num: 2. Device: /dev/sde
PASS [Completed]
SCSI ID: 524e2d303032 Total paths: 2. Writable paths: 2.
PASS [Completed]
- Testing LUN with SCSI ID 524e2d303031
Path num: 1. Device: /dev/sdb
PASS [Completed]
Path num: 2. Device: /dev/sdd
PASS [Completed]
SCSI ID: 524e2d303031 Total paths: 2. Writable paths: 2.
PASS [Completed]
END TIME: Mon Apr 4 15:20:38 2011
Multipath configuration verification results : PASS, Pass percentage: 100, Completed: Mon Apr 4 11:17:01 2011
Control path stress test results : PASS, Pass percentage: 100, Completed: Mon Apr 4 12:40:32 2011
Pool test results : PASS, Pass percentage: 100, Completed: Mon Apr 4 12:41:41 2011
Functional test results : PASS, Pass percentage: 100, Completed: Mon Apr 4 15:20:40 2011
End of XenCert certification suite.
Please find the report for this test run at: /tmp/XenCert-e309450a-25c0-45f2-97d0-dc473fb42702.log
Test end time: Mon Apr 4 15:20:40 2011
Execution time: 5 hours, 7 minutes, 50 seconds.
