chaps
Jan 25, 2012Aspirant
Compatible TVs
Sorry if this has already been answered but couldn't seem to find anything... Does anyone know what TVs currently out there that will stream from my ReadyNas Ultra 4 Plus? I've noticed most of the...
virgiliomi
Feb 29, 2012Aspirant
Most DLNA-compliant or compatible TVs won't have any problem accessing your media from your ReadyNAS. The issue you'll likely have is that the TV may not support the FORMAT that your music or video files are encoded in, and the ReadyNAS doesn't do any transcoding to other formats out-of-the-box. So make sure that whatever TV you are considering purchasing will support your music and/or video file formats. If not, either pick a new TV, look to a third-party product that supports transcoding to replace ReadyDLNA (and note that the ReadyNAS isn't the best solution for realtime transcoding of higher resolution video files), or re-encode all of your media to a format your TV supports.
