P--and--T
Sep 26, 2015Aspirant
Compression on ReadyNAS 316
I have a ReadyNAS 316 fully outfitted with 6x4TB HDD which gives me 18.17TB in Raid5. (Firmware6.2.4) This morning I checked the system and it said 7.64TB remaining. I elected to select all t...
- Sep 27, 2015
P--and--T wrote:
So if I created a new directory and copied a few thousand files from their existing location to the new location, would they be compressed along the way?
Yes.
Note that jpg (and video files, mp3/mp4/ogg audio files) are compressed already. So they won't really benefit from this. RAW photos might losslessly compress, though I don't think you'll see much there either. So you might as well keep compression off on the shares that contain these files.
Docs and PDFs generally will compress.
P--and--T
There was a typo in the third to last sentence
The unit is approximately 50% photos, the rest business files like PDFs and QuickBook backups etc.
mdgm-ntgr
Sep 27, 2015NETGEAR Employee Retired
See e.g. https://btrfs.wiki.kernel.org/index.php/Compression
Only files written after enabling compression would be compressed. Some files will compress better than others.
- P--and--TSep 27, 2015Aspirant
Thankyou
- StephenBSep 27, 2015Guru - Experienced User
Yes.
- Jun 06, 2017Retired_Member
- Aug 02, 2016Retired_Member
