aguden_guden_co
Aug 29, 2014Luminary
Connection is untrusted
I just got a new ReadyNas 314 with 3 6TB drives and would like to figure out how to get rid of the problem of "This connection is untrusted." I am using Firefox on a Windows 7 PC. I can get to the ...
Aug 29, 2014Guru - Experienced User
Have you tried starting FireFox in "safe" mode - by holding down shift when you launch it. There is an option to "reset" when you do that, which you could also try. https://support.mozilla.org/en-US/kb/re ... feature-do
Also, when you click on "technical details" what exactly does it say?
