aguden_guden_co
Aug 29, 2014Luminary
Connection is untrusted
I just got a new ReadyNas 314 with 3 6TB drives and would like to figure out how to get rid of the problem of "This connection is untrusted." I am using Firefox on a Windows 7 PC. I can get to the ...
aguden_guden_co
Aug 30, 2014Luminary
Starting Firefox with the shift key down allowed me to reset it. This then restarted and I got the same sequence except that after I got the certificate, the check box for adding the certificate permanently was checked. Evidently since I was running FF in a private/secure (not sure of the exact term) mode, it wouldn't let me do that. I will get back to the private browsing and reboot and see if everything is still ok!
Thanks for the great suggestion. This forum rocks!
