Dragonfan09
Jun 15, 2016Aspirant
Connection lost
So, I'm having an issue maintaining a connection to the storage. I am able to ping the device, I can open the web interface, however whenever I try to go into anything it says connection lost try ma...
- Jun 29, 2016
I was able to use the boot menu to reinstall the OS and it worked. I am now able to get into it and everything is showing healthy and proper inside http now.
Thanks all for the advice
Jun 15, 2016Guru - Experienced User
Possibly the OS partition is getting full.
First of all, you should update (or create) a backup of the data.
After that, if you have SSH enabled on the NAS you can check for OS fullness. Or you can contact support (ask about per-incident support). A third option is to do a factory reset, rebuild the NAS and restore the data from backup.
