Dragonfan09
Jun 15, 2016Aspirant
Connection lost
So, I'm having an issue maintaining a connection to the storage. I am able to ping the device, I can open the web interface, however whenever I try to go into anything it says connection lost try ma...
- Jun 29, 2016
I was able to use the boot menu to reinstall the OS and it worked. I am now able to get into it and everything is showing healthy and proper inside http now.
Thanks all for the advice
Retired_Member
Jun 15, 2016It could be that the GUI is completely offline but when you open it, you actually see the cache.
Could you try in clearing the cache of the browser (usually CTRL + R, or CTRL + F5), private browsing mode or with another browser (to avoid the cache issue) and confirm if you actually see that GUI.
Also, is the content of the GUI you see all in capital letters (that would confirm a cache page, in this context).
Finally, I agree, you should have a backup of your data. A RAID array provide redundancy, which doesn't replace an external backup.
It's a bit like the spare wheel in your car, it wouldn't help if the engine breaks down... and you'd still be left alone on the side of the road.
