Dragonfan09
Jun 15, 2016Aspirant
Connection lost
So, I'm having an issue maintaining a connection to the storage. I am able to ping the device, I can open the web interface, however whenever I try to go into anything it says connection lost try ma...
- Jun 29, 2016
I was able to use the boot menu to reinstall the OS and it worked. I am now able to get into it and everything is showing healthy and proper inside http now.
Thanks all for the advice
Dragonfan09
Jun 29, 2016Aspirant
Ok, so I was able to boot into read only mode and create a back up of my data. How do I check for OS fullness as was mentioned in a previous comment and if it is OS fullness what is the solution there?
aks
Jun 29, 2016Virtuoso
I think that's only possible if you can get ssh access, and to do that you need to install the "enable ssh" add-on.
One other this to check is to delete all the logs, which I think is what fills the OS volume - do that via the web i/f -> System -> Info, then clear logs.
- Dragonfan09Jun 29, 2016Aspirant
Yea I'm not able to ssh into it or http into it. When using ssh it says connection refused, and when I using http it says the device is offline.
- aksJun 29, 2016Virtuoso
If it is a 4-bay, what does the display show?
