Dragonfan09
Jun 15, 2016Aspirant
Connection lost
So, I'm having an issue maintaining a connection to the storage. I am able to ping the device, I can open the web interface, however whenever I try to go into anything it says connection lost try ma...
- Jun 29, 2016
I was able to use the boot menu to reinstall the OS and it worked. I am now able to get into it and everything is showing healthy and proper inside http now.
Thanks all for the advice
aks
Jun 29, 2016Virtuoso
If it is a 4-bay, what does the display show?
Dragonfan09
Jun 29, 2016Aspirant
