PipingRockIT
Aug 18, 2016Aspirant
Connectivity issues from different subnet
Recently we've been having issues with connectivity to our NAS when connecting from another subnet. We have two networks, 192.168.5.x and 192.168.10.x, and the NAS is on .5.x. Users on .5.x have ze...
- Sep 02, 2016
I understand that you suspect that the antivirus feature of the gateway you use may be the root cause in how it checks cifs/smb packets.
Aug 18, 2016Guru - Experienced User
Is the gateway address on the NAS correct (255.255.255.0)? I'm also wondering if you might have an IP address conflict.
If those are ruled out, then it seems more likely to be a router or switch issue. Do you have any way to gather stats on the connection path? If not, you could try running an extended ping test of the NAS from the 10.x subnet..
PipingRockIT
Aug 19, 2016Aspirant
Gateway is correct, as users on the .10.x network do see the nas. It is just when opening or modifying files do these issues occur.
I ran a ping test from that network overnight and the highest ping time I saw was 102ms with the majority being <1ms-3ms and an occasional one in the teens and 20 ms range.
