2twisty
Aug 30, 2014Aspirant
Constant Disk activity RN104 w/6.1.8
My "activity" light NEVER stops unless I turn off the power. NEVER. I usually run MYSQL server (for the XBMC database) and the NAS holds my video files. The XBMC accesses the NAS via NFS. Respo...
nsne
Nov 15, 2014Virtuoso
mdgm wrote: Do you have SSH port forwarded? I am seeing a lot of login attempts in the logs coming from an I.P. address in China.
Thanks, mdgm. I had set up port forwarding ages ago while I was traveling and never disabled it. My logs were full of brute force SSH attempts. (Yeah, I'm looking at you, 76.12.235.157.)
mdgm wrote: I see you are using snapshots on a lot of shares.
I disabled snapshots as well as bit rot (COW). I might enable them later if I feel like the NAS can handle it. Right now they're not necessary because I still have my Ultra 4 as a backup, and the data hasn't changed greatly.
mdgm wrote: It's possible one or more of your add-ons might be preventing the disks from spinning down.
My first assumption was Plex, but I think I've found the culprit: iTunes. Something is very, very wrong with forked-daapd based on the logs. When I finally did get the ReadyNAS iTunes library to load in iTunes, this is what I saw:
In case it's not clear, each track has seven entries.
So it looks like the iTunes service scans the media files up to a point, then there's the following series of messages:
Nov 14 21:03:31 ReadyNAS forked-daapd[1907]: main: Got SIGTERM or SIGINT
Nov 14 21:03:31 ReadyNAS forked-daapd[1907]: main: Stopping gracefully
Nov 14 21:03:31 ReadyNAS forked-daapd[1907]: main: mDNS deinit
Nov 14 21:03:31 ReadyNAS forked-daapd[1907]: main: Remote pairing deinit
Nov 14 21:03:31 ReadyNAS forked-daapd[1907]: main: HTTPd deinit
Soon forked-daapd enters a "failed state" before restarting. And the cycle repeats itself. So it just keeps scanning and rescanning. Once I disabled iTunes, I had a quiet ReadyNAS again.
Also, it looks like the logs were full of attempts to send alert messages via SMTP every minute or so. I tried setting up Gmail and Zoho accounts, but neither sent successfully. Has anyone successfully configured a mail account to send alert messages? [EDIT: Now mail alerts are working. Go figure.]
