churchers
Aug 07, 2017Aspirant
Consumed space wrong after rollback
I have a backup share on a RasyNas running the curent firmware (6.7.5) This contains around 50GB of backups (which come from another ReadyNAS via rsync). I made a silly mistake and set up a new ...
Aug 07, 2017Guru - Experienced User
Perhaps start by deleting all remaining snapshots for the share.
If that doesn't help, try running a balance from the volume settings wheel.
mdgm-ntgr
Aug 07, 2017NETGEAR Employee Retired
You could also disable quotas on the volume and then re-enable them. It may be that a quota rescan is all that's needed.
