gezzyboy
Sep 12, 2013Aspirant
Content Source Removed
I am having an issue with my ReadyNAS Ultra 2 and WDTV Live, all with latest Firmware etc etc: After pretty much 30mins (i have timed it) the WDTV will stop seeing the ReadyNAS and I will have to go t...
vandermerwe
Sep 13, 2013Master
You probably won't like this suggestion, but have you considered custom firmware for your wdtv live. It seems the standard network options are very limited in the standard firmware. There is at least one custom firmware which seems to offer many more options. It may take some learning and effort to get it set up but if it improves your devices functionality it may be worth it.
http://b-rad.cc/wdlxtv/
..is an example. It allows you to mount nfs shares too, nfs should give you better performance.
