gezzyboy
Sep 12, 2013Aspirant
Content Source Removed
I am having an issue with my ReadyNAS Ultra 2 and WDTV Live, all with latest Firmware etc etc: After pretty much 30mins (i have timed it) the WDTV will stop seeing the ReadyNAS and I will have to go t...
Sep 14, 2013Guru - Experienced User
Since accessing the network share is working on the WDTV (the problem is limited to DLNA) it seems unlikely that the problem to be related to file permissions or workgroups. The fact that the movie simply stops in the middle of playback also suggests that the the cause lies elsewhere.
The ssdp frequency is a possibility. Some people have found that turning off upnp services on their router helps dlna discovery (as sometimes these services amount to a upnp proxy, which can get in the way). Again,if the WDTV is connected wirelessly, look carefully at the wifi router settings and see if there is any checkbox related to broadcast or multicast. If there are, make sure such services are enabled.
