geojay
Aug 14, 2016Guide
Continuing existing remote backups after replacing existing NAS
I've recently replaced a ReadyNAS Duo with a RN204. I'm now setting up the backups from this NAS to a remote ReadyNAS Duo. I'm used to the two NASs doing incremental Rsync backups where only the chan...
- Aug 14, 2016
geojay wrote:
How strange, I missed the option for First Time...
Am I right in thinking this means every file will be sent again? If that's the case, I assume the existing files will be overwritten automatically by the newly sent ones?
yes
geojay wrote:
Regards securing the exchange, are you able to point me at something that explains what I need to do on the ReadyNAS Duo?
There is an add-on you need: http://www.readynas.com/contributed/super-poussin/FreeDuo_1.7.bin Though I haven't used it - hopefully someone else will chime in.
geojay
Aug 14, 2016Guide
Also, is it possible to secure the transfer or am I right in thinking, the remote ReadyNAS duo isn't powerful enough to support this?
Thanks
Aug 14, 2016Guru - Experienced User
(a) run full backup first time is an option on the RN204, so look again at that.
(b) It can be secured, and I recommend doing that. It requires installing a certificate on the systems.
- geojayAug 14, 2016Guide
Many thanks,
Geoff
- StephenBAug 14, 2016Guru - Experienced User
yes
- mdgm-ntgrAug 14, 2016NETGEAR Employee Retired
The performance with Rsync over SSH likely be quite poor with the Duo.
You may be better off getting another RN204 or perhaps rather than using Rsync over SSH setting up a box to box VPN between the two sites if your routers at each site support this.
