geojay
Aug 14, 2016Guide
Continuing existing remote backups after replacing existing NAS
I've recently replaced a ReadyNAS Duo with a RN204. I'm now setting up the backups from this NAS to a remote ReadyNAS Duo. I'm used to the two NASs doing incremental Rsync backups where only the chan...
- Aug 14, 2016
geojay wrote:
How strange, I missed the option for First Time...
Am I right in thinking this means every file will be sent again? If that's the case, I assume the existing files will be overwritten automatically by the newly sent ones?
yes
geojay wrote:
Regards securing the exchange, are you able to point me at something that explains what I need to do on the ReadyNAS Duo?
There is an add-on you need: http://www.readynas.com/contributed/super-poussin/FreeDuo_1.7.bin Though I haven't used it - hopefully someone else will chime in.
geojay
Aug 14, 2016Guide
Many thanks,
Geoff
Aug 14, 2016Guru - Experienced User
yes
