Kojak1
Feb 11, 2012Aspirant
Convert DVD to Xbox
Hi, I have my own DVD's of birthdays etc, which were all made on Pinnacle - so are in VOB format. I would like to make these work on the xbox - via the NAS (Duo V2). I have tried several ways, ...
Kojak1
Hi,
Yeah sorry I probably didnt explain it properly.
I meant more the picture size.
The first one I did was okay'ish quality but less than the original DVD - but I guess I need to adjust the 'constant quality' scale.
With this first 'test' video, it worked okay on xbox, but on my TV (samsung) it would only play in the resolution it was made in, which is 720x576 and wouldnt make it full screen.
To be honest, I am a tad confused by it.! I have only ever used Pinnacle Video Editing in the past, which is simple.!!
The DVD I did earlier went from around 4gb to under 1gb - so it obviously reduced quality quite a bit.
I just want them like for like.
