Kojak1
Feb 11, 2012Aspirant
Convert DVD to Xbox
Hi, I have my own DVD's of birthdays etc, which were all made on Pinnacle - so are in VOB format. I would like to make these work on the xbox - via the NAS (Duo V2). I have tried several ways, ...
Feb 12, 2012Guru - Experienced User
I suspect this is a codec issue, not a screen size problem.
Kojak wrote: Hiya,
I found that Pinnacle can indeed recode the video, which I did last night.
But the xbox says unsupported format.
It even says that with the Handbrake version - if I have changed screen size.
Cant quite believe it is so limiting.!!
-is the file extension .mp4 or .avi
-what audio and video codecs did you choose?
From what I have read, the xbox only handles
x264 + AAC audio inside mp4
xvid + AAC audio inside mp4
xvid + AC-3 audio inside avi
