Kojak1
Feb 11, 2012Aspirant
Convert DVD to Xbox
Hi, I have my own DVD's of birthdays etc, which were all made on Pinnacle - so are in VOB format. I would like to make these work on the xbox - via the NAS (Duo V2). I have tried several ways, ...
Kojak1
Feb 12, 2012Aspirant
signalman wrote: Hi Kojak
I use Pinnacle Studio 15 for making my home videos from my Canon HD10 Camcorder
Pinnacle will also 'import' DVD's and allow you then to export them to MP4's which the xbox will play just fine streamed from a duo v1
It's not the fastest way of doing it, but it works for me
Hope that helps (a bit)
Hiya,
just made a quick one using Pinnacle and mirrored the settings on the previous website - and it worked.
It was:
VIDEO - 1280x720, 5000 kbits/sec, 30 frames/sec
Audio - MPEG-4, 128 kbits/sec, 16 bit stereo, 48 khz.
The file went from 94MB to 470MB.!! And the quality wasnt 100%, and it was a little juddery.
However, and this may be where I am mucking it up, the original video (shot on camcorder) was 854x480, 4000 kbits/sec, 25 frames per sec.
Would this be the error of my ways ??
