tonydi
Jun 08, 2016Luminary
Copy files to USB drive by age
ReadyNAS 10200 on current firmware/OS I'm going to use the ReadyNAS to hold backup images for multiple PC's, one folder for each computer. Each folder will have up to 3 image files. I'm g...
Jun 08, 2016Guru - Experienced User
If you re-organize the data, you could automate it, though it is clunky.
For instance
Create a week-1 share (where the current backup is always stored for each PC), a week-2 share and a week-3 share. Also create a dummy empty share.
On Thursday automatically backup up week-3 to USB
On Friday back up week-3 from week-2 (using the option to delete week 2 contents)
On Saturday back up week-2 from week-1 (using the same option)
On Sunday back up the dummy empy share to week 1 (again using the option to delete) in order to clear it for new backups.
Then fresh backups from the user PCs can be written to week-1 from Monday-Friday.
If you use snapshots, you can get the similar effect in a different way.
Create one backup share, and one dummy empty share. Set the snapshot retention for the backup share to 3 snapshots.
Back up the current contents of the backup share to USB every Saturday
Make a snapshot on Saturday as well.
Run the dummy backup on Sunday to delete the current contents of the backup share (migrating those contents to the most recent snapshot).
Once that dummy backup job runs, you'll have 3 backups in the snapshots and an empty share. You'll also have the most recent backup saved to USB drive (not the oldest).
tonydi
Wow, Stephen, that's really clever, thank you for that.
First I must apologize because I can see that I didn't provide enough info on what I'm trying to do. The USB drive will be used for off-site storage and will only be connected once a week for as long as it takes to copy the latest backups. Plus, I don't think your solution is going to work for this situation because if I understand your process, I won't have enough disc space to accomplish this.
I'm looking at some scripting using forfiles that the local user could run when she plugs in the USB drive. If I can give her an icon to click then I think we can get a good result.
Thanks again for your help!
- StephenBJun 08, 2016Guru - Experienced User
The disk usage for both alternatives should be about the same as your original concept. (in the first, there are three shares each holding one week's backup, in the second there is only one share, but the older backups are in the snapshots).
Though a script has the advantage that there are no timing issues coordinating the multiple backup jobs..
