AndreasKa
Jan 16, 2015Tutor
Copy instead of move from external storage?
Hi All, I'm copying a load of data onto my 314 via the eSATA connection. The default function is moving the data so that the external disk doesn't contain the data after it's complete. Is there a ...
Jan 17, 2015Guru - Experienced User
If you right-click on the folder you will see "copy". After you click it, paste will appear when you right-click.
