bkv
Oct 24, 2011Aspirant
Copy to nas with rsync
Hi, I try to backup my linux laptop to the nas using rsync, but I get connection refused. I have set up the backup share to be accessible with rsync. What have I missed?
Bjørn
bjorn@linux-oxsa:~/rsync> rsync -C --exclude-from=filter_backup -aruv /home/bjorn/ gerd@nas1:/backup
ssh: connect to host nas1 port 22: Connection refused
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(601) [sender=3.0.7]
Bjørn
- amac27Aspirant
- bkvAspirantThank you, I got something running now. I was looking for a way to run rsync on the lap-top and push the data onto the ReadyNAS, but this documentation led me to set up a back-up job on the NAS to pull data from the lap-top. The rsync deamon has to be started on the lap-top. This will work, too.
One may also benefit from this link: http://www.linuxjournal.com/article/6508?page=0,0
Putting a value into the path-field on the back-up job was not straight forward. Instead of just the path to the directory to back up it needed a rsync module name. This is explained in the link above.
-Bjorn
