redtomato
May 01, 2010Aspirant
Copying between volumes
Hi, Is there any faster way to copy between two shares? Copying over CISF/Windows between network drives is taking very long. My ReadyNAS has got RAIDator 4.1.6. Thanks.
mdgm-ntgr
May 01, 2010NETGEAR Employee Retired
If you were moving I'd suggest logging in as admin. Open \\ip.address.of.nas\c and move files within there. As for copying, it's not so simple. Perhaps try a file manager add-on: http://www.readynas.com/?cat=65.
Btw do you know how to use Linux shell commands? If so there's another option to consider.
Also note there's a difference between volumes and shares, so your thread title is a bit misleading.
