redtomato
May 01, 2010Aspirant
Copying between volumes
Hi, Is there any faster way to copy between two shares? Copying over CISF/Windows between network drives is taking very long. My ReadyNAS has got RAIDator 4.1.6. Thanks.
Lichon
May 02, 2010Aspirant
Accessing a ReadyNAS is NOT model dependent.
I strongly suggest you start with mounting "\\NAS\c" (only admin login works) and use your connection protocol (CIFS,NFS,AFP) to move files & folders around between shares.
On windows you are required to unmount all "\\NAS\<share>" mounts first.
That WILL work, but if you want direct linux console access then you need to install the SSH-addon. Remember to read the warning!
