redtomato
May 01, 2010Aspirant
Copying between volumes
Hi, Is there any faster way to copy between two shares? Copying over CISF/Windows between network drives is taking very long. My ReadyNAS has got RAIDator 4.1.6. Thanks.
redtomato
May 02, 2010Aspirant
Lichon wrote:
I strongly suggest you start with mounting "\\NAS\c" (only admin login works) and use your connection protocol (CIFS,NFS,AFP) to move files & folders around between shares.
On windows you are required to unmount all "\\NAS\<share>" mounts first.
When I try to mount using command
net use N: \\192.168.10.110\c /user:admin
in Windows Command, I'm getting "System error 5 has occured."
"Access is denied."
I'm pretty much sure, I'm entering right password.
Any idea?
