redtomato
May 01, 2010Aspirant
Copying between volumes
Hi, Is there any faster way to copy between two shares? Copying over CISF/Windows between network drives is taking very long. My ReadyNAS has got RAIDator 4.1.6. Thanks.
Grievous
May 04, 2010Aspirant
Lichon wrote: Does this mean backup now supports move instead of copy ?
Grievous wrote: If you want to move a lot of data, but only need to do it on rare occasion, I actually suggest using backup jobs. <snip>. Set your source as the original share/folder, and then the destination as the newshare/folder.
If not, then space might be an issue as the job copies the content meaning you require twice as much space.
No, I said to use the backup so you don't need to login to the ReadyNAS via SSH or leave a client PC occupied running the copy between shares.
