john_es
Apr 17, 2014Aspirant
Copy/move between shares is sloooooooooooow...
I have SSH'd into my 316 and am doing cp and mv's... trying to move a bunch of data from one share to another (/data/share1 to /data/share2). It's slow. Like, really slow (maybe 90 seconds per GB)...
May 10, 2014Guru - Experienced User
rotordave wrote: How can it be acceptable that ordinary move operations are not possible on this device? What is being done to address this? Aside from forcing users to use a single share? The fact that BTRFS has this limitation is irrelevant - I need to be able to move large files without coping them...!
You apparently missed a post further down:
It seems to me that the web ui could also use the --reflink option.
Skywalker wrote: ...future firmware releases will support this sort of operation via SMB2's FSCTL_SRV_COPYCHUNK command, which is for server-side copies. But I don't know which SMB clients use that command, other than Windows Server 2012.
The bottom line is that it works this way for now. Netgear might be able to put in limited support for --reflink in various spots. But this is a tradeoff - the snapshots are also a feature that many users want. The ability to turn snapshots on/off on a share-by-share basis is also needed, and supporting that means that moves between shares (subvolumes) are treated as copy/delete by the file system. Some users will prefer the snapshot control, others don't care about snapshots, and would rather have the direct move.
I imagine there could also be a setting when you create the share that doesn't set it up as a subvolume - permanently disabling snapshots. There'd be no way to undo that without deleting the share.
You could attempt to do this manually in ssh. Rename "Downloads" temporarily in SSH, and create a Downloads folder manually with the normal permissions. There might be some side effects, but if it works you'd end up with a downloads folder that is not a subvolume.
