JimmyChen
Jan 13, 2017Aspirant
Corrupt Boot - "Err: Could not mount root RAID d"
Hello, i bought this NAS Box from ebay!. but i don't know how to set it up ? When I installed 1 or 4 disks , the LCD showed the error: "Err: Could not mount root RAID d" ..! Can you tell me how ...
- Jan 18, 2017
For most users, the best RAID format is to use the default XRAID. That can be expanded w/o data loss, and it has protection for a single disk failure.
If you want maximize storage space and don't care about expansion or protection from a disk failure, then the best option for that is to use flexraid and create one volume for each disk.
To do that, you need to start over and set up the NAS again. Remove all disks but the first, then do a factory reset using the boot menu. You have a 10 minute window to configure the system for flexraid using RAIDar.
Details are in the hardware and software manuals for your ReadyNAS here: http://downloadcenter.netgear.com/en/product/RNDP4000%20(ReadyNAS%20Pro%204)#searchResults
JimmyChen wrote:
?. Just put in & read the data inside (with NTFS format).
Your NAS doesn't use NTFS. It uses EXT. When you insert a disk into the NAS, the data on it will be wiped.
The NAS doesn't let you create a "library" of hard drives that you can insert/remove on demand. The disks need to remain in place after you create the volumes.
JimmyChen
I AGREE TO ALLOW NETGEAR REMOTE ACCESS TO MY NETGEAR PRODUCTS AND OTHER EQUIPMENT TO PERFORM TECHNICAL SUPPORT SERVICES IN ACCORDANCE WITH THE TERMS AND CONDITIONS.
Name:_______Jimmy_____________ Date:_______14/01/2017__________
The debugmode number is: 50410
Thanks for your quickly reply !!!
Jimmy.
Jimmy.
mdgm-ntgr
Jan 15, 2017NETGEAR Employee Retired
Which model and which firmware?
I understand you now have reset it successfully but don't like it that it has created a single volume C using all your disks?
- JimmyChenJan 16, 2017Aspirant
my NAS is: ReadyNAS Pro 4 : RNDP4000 - Model : RND-4A
Firmware Current: 4.2.30
Yeah! Correct ! it has created a single volume C using all to 1 disks. But I want It separate 1-2-3-4 .
many thanks for your helping !
and ... Please give me a suggestion of RAID Setting !
because I just only want to make a big storage with 4 hard drives ( has data inside ready ) , Like plug & play & when i put in a hard drive ( with data inside ) I don't want it Resync or Format it whatever ?. Just put in & read the data inside (with NTFS format).
can i do that with Flex-RAID-0 ?
Thanks
- StephenBJan 18, 2017Guru - Experienced User
