Johnhyzhang
Aug 22, 2015Aspirant
Corrupt Boot - "Err: Could not mount root RAID d"
Hello, My storage equipment NETGEAR Model No. RND4A Model name: ENDU40000 The machines has 3 discks – the first two have each 2GB and the third one 1.5GB – which is not used 2GB disk: SEGATE) I a...
Johnhyzhang
Many thanks for your prompt reply.
I suppose the updated FW was raidiator-x86 version 4.2.27
I did not do FW update for years, I don't remember the last version on my sustem.
I do not have a back-up out of the Readynas. I suppose there is copy in the system of the sotrage?
After several tentaives, now the boot started. In Raidar, I see disk one is "health". I can browser it and see all my folders, but I can not access to them. When I want to connect to them through windows explore, it aks the use namer and password, but I can no longer use the old ones.
The Admin pagfe is empty - I can login, but see nothing.The second disk is showed as "died" in Raidar with a red X on it.
I am not an expert for the Ready system - and I am worry about my data on the disk.
Do you have a solution for this?
Please give me the instruction to remotly connect to my computer and payment to Readynas for this extra service is ok.
Many thanks
John
JennC
Aug 22, 2015NETGEAR Employee Retired
Hello Johnhyzhang,
I checked your profile and found that you have opened a ticket with the support center.
Your case is possible for L3 escalation. However, support contract is needed as the support warranty of your unit already expired.
As far as I can see, there is still hope retrieving your data. Please also try to access the admin page using a different web browser, in case you are able to, see permissions settings of the shares. See this article here for you to have idea how this is done.
