Johnhyzhang
Aug 22, 2015Aspirant
Corrupt Boot - "Err: Could not mount root RAID d"
Hello, My storage equipment NETGEAR Model No. RND4A Model name: ENDU40000 The machines has 3 discks – the first two have each 2GB and the third one 1.5GB – which is not used 2GB disk: SEGATE) I a...
Johnhyzhang
Hello,
I just checked the model of my system:
Netgear ReadyNAS NV + v2 with four bays, X-RAID2
Thanks
John
vandermerwe
Aug 22, 2015Master
Yes it sounds like your OS partition is full, although there may also be some other issues related to your attempt to upgrade the firmware and the OS reinstall.
My suggestion to wait for a response from someone on the forum still stands. There may be someone who can help you directly. I would expect if you do get an offer that this happens usually quite quickly (1-2 days)
Edit: Reading through your second post again it seems that there are indeed some additional issues, so follow through with the support request that you have already made.
