Itcareon
Apr 06, 2025Tutor
Coudnt open the netgear advanced network storage model no: RND- 4G. Showing booting on the display
Apr 07, 2025Guru - Experienced User
I believe you have an RN424. Do you also see an RN42400 label?
Have you tried installing RAIDar and seeing if you could get the log zip file from RAIDAr? It might also be able to run the diagnostics.
Itcareon
Apr 07, 2025Tutor
Yes it is RN 42400 , while powering up it only showing booting on the Display
- StephenBApr 07, 2025Guru - Experienced User
There are several causes, most are disk-related.
See if RAIDar lets you run the diags or get the log zip.
If it doesn't, then try powering down the NAS and remove the disks (labeling them by slot as you take them out). Then power up, and see if the NAS reports a no-disks status.
BTW, make sure the NAS is powered down then you put the disks back.
