ipb_uk
Feb 19, 2018Aspirant
CPU fan speed stuck at 4218rpm
Hi, The CPU fan seems to be stuck at 4218 & 3515 rpm. Not sure how long it's been like this but at least a week. Room temp = 23c CPU = 45 System = 55 Disk1 = 38 Disk2 = 38 Disk3 = 37 Di...
ipb_uk
It's on 6.9.2 with 6x6TB disks.
I'd forgotten about my signature as it doesn't show on my PC. Hopefully I've updated it and can bee seen by someone, I can't see it in my posts though.
ipb_uk
Of course the sig. shows silly me.....
- SandsharkFeb 20, 2018Sensei
Sounds like a configuration error. If you have SSH enabled, please post the contents of ./etc/sensors.d/system.conf.
- ipb_ukFeb 20, 2018Aspirant
Contents is......
chip "colabel temp2 "CPU"compute temp2 @%35, @%35ignore temp3chip "w83627dhg-isa-*"label in1 "DDB18"set in1_min 1.62set in1_max 1.98set in2_min 3.3 * 0.90set in2_max 3.3 * 1.10label in3 VCC3set in3_min 3.3 * 0.90set in3_max 3.3 * 1.10label in4 VCC1_25set in4_min 1.17set in4_max 1.32label in5 "VCC1_5"set in5_min 1.41set in5_max 1.58label in6 "VCC1_05"set in6_min 0.98set in6_max 1.10set in7_min 3.3 * 0.90set in7_max 3.3 * 1.10set in8_min 3.0 * 0.90set in8_max 3.3 * 1.10label fan1 "System"set fan1_min 600label fan2 "CPU"set fan2_min 150label fan3 "System"set fan3_min 600ignore fan4ignore fan5label temp1 "System"set temp1_max 80ignore temp2ignore temp3ignore cpu0_vidignore intrusion0- Supertramp11Feb 20, 2018Luminary
I ran 6.9.1 and currently run 6.9.2 on my PRO 6 coming from 6.5.0 and I have to say that the fans never worked better than with 6.9.x.
This is not an immediate help to resolve your problem, but I thought I share this.
