ipb_uk
Oct 26, 2017Aspirant
CPU Fan stuck on 4218 rpm
Hi, The CPU of my Pro RNDP6000 is stuck on 4218 rpm. The box is on 6.9.0. The cpu temp is 47. The fan starts off slow at around1500rpm and works its way up 4218 rpm after about 10 minutes and st...
Sandshark
Nov 18, 2017Sensei
OK, so that is only for units that have the three-pin fan connected ot the IO card instead of the 4-pin one connected to the motherboard. I do note that the patch is no longer reachable.
Supertramp11
Nov 19, 2017Luminary
For those interested, the patch can be downloaded again.
