sebbb
Apr 13, 2016Aspirant
CPU temperature alert on readynas 2120
We are monitoring our infrastructure with Zabbix. We have 8 Readynas 2120v2 (used only as backup devices with rsync) monitored by SNMP using a template found on Zabbix community pages. This monitorin...
- Apr 13, 2016
Then it's fine.
In 6.5.0 we will have the option to set the fan mode. If you don't care about the noise you could set it to cool. There are three modes quiet, balanced and cool.
We have ReadyNASOS 6.5.0-T338 (Beta 2) available
mdgm-ntgr
Apr 13, 2016NETGEAR Employee Retired
Which firmware are you running?
Did you get any errors in the web admin UI. That temp sounds O.K.
- sebbbApr 13, 2016Aspirant
Hi,
we are running the latest 6.4.2 firmware. The web admin ui don't show any errors in the logs.
- mdgm-ntgrApr 13, 2016NETGEAR Employee Retired
Then it's fine.
