hellwiththis's avatar
hellwiththis
ReadyNAS 426 - problem with alert emails
ReadyNAS 426.
Hello friends, I have suddenly developed a problem with email alerts. It's been working all along, but yesterday it stopped. No idea why; I haven't changed anything.
I went to the control panel and tried sending a test message and got this error:
Unable to send a  test message.
Cannot send a test message. Check authentication settings.
Code: 500810001
Error from msmtp
Any help is appreciated. peace
  • StephenB's avatar
    Jun 10, 2022
    hellwiththis wrote:
    I must admit I'm a bit confused here....didn't we just establish that I can't use gmail? Unless I want to deal with their two-tiered security thing, which I really don't.
    There are two parts to the alert setup
    1. who you want the alert emailed to
    2. what email account you want the alert mailed from.
    You can set up the the alerts to be sent from Yahoo, and have them sent both to yahoo and to gmail.
    Not sure if you can remove yahoo from the to list or not - it didn't matter to me, so I didn't try that.
    hellwiththis wrote:
    About that, what are you going to do?
    I am still leaving 2FA off with gmail for now.  I might change that later on (since I can trust the computer I normally use to read email).
    But as far as alerts go, I've already shifted to sending from my yahoo account to my gmail address, and I think I'll just leave it that way.
  • StephenB's avatar
    hellwiththis wrote:
    ReadyNAS 426.
    Code: 500810001
    Error from msmtp
    Are you using gmail?  I ran into this also.  Google deprecated their "allow less secure apps" setting.  I think you can still use app-specific passwords, but only if you have two-factor authentication enabled on the account.  If you don't want to do that, you'll need to switch to a different email provider to send the alerts.
    • hellwiththis's avatar
      hellwiththis
      Oh geez. There's the answer. StephenB you have solved my problems again! Thanks very much. I wonder if a yahoo account could do it?
      Thanks very much brother, peace
      • StephenB's avatar
        FWIW, I was thinking along the same lines.  Yahoo does work (though it does require an app-specific password).
        Though if you have a legacy NAS with only TLS 1.0 support ( 4.1.x firmware), then Yahoo's SMTP server will reject the email alert.  Not a problem with the 426, just the sparc-based platforms like the NV+ v1 and Duo v1.
ProSupport for Business
